302 vs 360
on
1 Post
hey the 302w's are not gutless! unless its a mid to late 70s smog motor, but then most motors of that time period where poor on power and where horrible in stock form,
i would suggest a 1971 or older 302w, but then i can't really recommend many engines in the late 70s since there all low compression smog motors, and thus i think they should be rebuilt, i really wish they never went the route of going low compression and all that smog garbage,
-Brent
-Brent
-Brent
-Brent
I also re-ringed & bearinged a 1989 GT short block, used GT40 iron heads from a Lightning pick up with a motorsport F303 cam, Edelbrock RPM intake intake, along with exhaust, TB, MAF, injectors etc. It dynoed 288hp at the wheels which would be around 330 at the flywheel.
My cousin has an 89 F-150 with an explorer motor with homemade dual exhaust, B303 cam, etc. It's a 5 speed and will smoke 33 inch super swampers on pavement in second gear with a spool in the rear end.
If you don't like EFI you can still take an engine from an 80/90s Mustang or Explorer and just pull the EFI off and bolt a carb'd intake to it. In my opinion the 80s Mustang motor is leaps and bounds ahead of an early 302. Rated at more power (even after the ratings change), forged pistons and roller cam.
I also have a 1985 Mustang GT. It's a 4 barrel carb, 5-speed with forged pistons and roller cam. I bet you'd like that one! Runs great too. Stock engine on street tires with just underdrive pulleys and an offroad H-pipe, I ran 13.96 @ 99mph, which is damn good for what it is.
bought a truck a few days ago, '76 F100, ended up having a 302 in it.
I'll keep it for now, but I was really interested in going with a big block. It runs tho, but I thought in 76 the 302's were phased out. Guess not.
Has a Motorcraft carb on it, 2barrell, I can't find a number, and was kinda wanting to rebuild it.
Anyone know what that'd be, 2100? 2150?
thanks,
Drew
thanks,
Drew
The 351W from a later F or E series is a better choice. More torque is what you need to get something heavy like a dentside moving. And, it bolts right in place of a 302.
Of course, a 460 is ideal.
The 5 liter ho is a good engine. It makes 300 lbs of torque which is really not bad at all for a heavy pickup. Only a few years came with forged pistons. The rest had hypereutectic pistons.
fordguy2100
13
06-09-2016 06:23 PM
1968FordF100
38
02-04-2013 10:51 PM
airbusflyboy
09-11-2009 03:13 PM
shunderwunder
03-15-2003 06:58 PM
