Roller Cam - Custom Comp Cam 351
Category: Engine - Intake/Fuel
Price: $100
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): S2000, CL, TL & Vigor
Item Condition: FL
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
Part # 35-000-8
Grind FW 3611F / 3612F HR 114.0
Serial A 3758
Valve Adjustment Hyd
Gross Valve Lift - Intake 0.513 Exhaust 0.513
Duration at .006 Tappet lift - Intake 270 Exhaust 276
Valve Timing
Open at .050 - Intake 1- BTDC Exhaust 50 BBDC
Close at .050 - Intake 39 ABDC Exhaust 6- ATDC
These specs for Cam Installed At 110 Intake Center Line
Duration at .050 - Intake 218 Exhaust 224
Lobe Lift. - Intake .3210 Exhaust .3210
Lobe Separation 114.0
The cam has about 7000 miles on it. I used it with AFR 185s, but it can be used with stock heads. It is a roller cam so you will need roller lifters.
