EFI to CARB conversion help - Ford Truck Enthusiasts Forums
Old 11-01-2009, 07:38 AM
quadracer173 quadracer173 is offline
quadracer173 is starting off with a positive reputation.
i have a 1989 ford f250 351w 5.8L and i am gonna do an efi to carb conversion and i was wondering what is needed and what parts i need to make it a carb
Old 11-01-2009, 07:56 AM
agfordman's Avatar
agfordman agfordman is offline
agfordman is starting off with a positive reputation.
a intake, carb, mechanical fuel pump, and some fuel line. why do you want to switch? you might want to search!!!!
Old 11-01-2009, 08:24 AM
i was told i would need a new ignition and distributor to is that true? and i am doing it as a project for my truck
Old 11-01-2009, 08:32 AM
agfordman's Avatar
ya that is true. is there something wrong with your efi, because by the time you get everthing for your carb swap it would be better just to fix your efi, and also what trans do you have?
Old 11-01-2009, 08:50 AM
1966Tbird's Avatar
1966Tbird 1966Tbird is offline
1966Tbird is starting off with a positive reputation.
don't use a mechanical fuel pump, use your fuel injection pumps and a bypass regulator. run a new return line that is 3/8ths or -6an i would also reccomend using -an line for everything since there is high pressure. russell sells the fittings to hook your return line to your tank and to run a pressure line off of your stock fuel filter. 3/8ths line (fuel filter) 640850 5/16ths line (return line to your fuel tank) 640860 . Use a toggle switch to provide power to your fuel pumps at the enertia switch (located on the firewall behind the brake pedal). Other than that you will need a new distributor, ignition coil, carb, and intake manifold. The green wire that goes to your distributor is your tach wire so cut it and hooko it up accordingly, the white wire is your power to the dissy so hook that up accordingly as well. I also used the white power wire for my electric choke. If you get a HEI distributor you will need an offset aircleaner base and stud. If you have an aod you have to shop up your factory throttle cable bracket and weld it back together so it will hold your throttle cables and your TV cable. They sell things that bolt onto the throttle linkage on a holley with the right ratio and all that good stuff to use with your TV cable on your aod. If you have an e40d then you will need to find a stand alone computer for it which is expensive-it is cheaper to just use a c6 or c4 or stick depending on what you are doing.
Old 11-01-2009, 08:51 AM
nothing is wrong with my efi just doing all this for a project.. i have a 4speed with drive manual trans.
Old 11-01-2009, 09:00 AM
alright well what would be a good distributor for doing this? and all i would need is a distributor,ignition coil, carb, and intake manifold?
Old 11-01-2009, 09:01 AM
1966Tbird's Avatar
you'll be fine then, you might want to use a lokar throttle cable or some other brand since the original throttle cable is like 2 feet too long to be used with a carb and look nice, if you use an aftermarket throttle cable then you can also use an aftermarket throttle cable bracket that bolts onto the carb instead of having to weld up your own
Old 11-01-2009, 09:04 AM
alright thanks, i was gonna use the msd distributor which one is good for the price?
Old 11-01-2009, 09:08 AM
1966Tbird's Avatar
a good distributor would be an msd one, i have the e-curve because i hate playing with advance springs and shooting them everywhere and losing them. i would not reccomend using a hei distributor they are a pain in the *** to get to clear your aircleaner and then you have to find an advance kit with the correct bushings that i couldn't find anyone who made.
but any of the msd ones are a good shot. i also like mallory distributors but stay away from points distributors the points tend to bounce at high rpms and kill horsepower.
as for the intake manifold you use it depends on what kind of power you are looking for and how well your heads flow...what kind of heads do you have on there? e7 heads? If you have e7 heads don't pick something too crazy since those heads flow like crap even when ported.
For your carb i am going to say between a 650 and 750 if your motor is pretty much stock.
while you are pulling off your fuel injection crap since you already have the motor torn apart all you need to do is pull your rockers off take your pushrods out and pull your lifters then take off the timing chain cover timing chain and the thing that holds your cam in the motor and swap out the cam too, this will give you a big power increase depending on what cam you chose though. Since you are going with a carb there is no restriction on what cam you can run!! it's not like that speed density bull**** lol
Old 11-01-2009, 09:10 AM
1966Tbird's Avatar
with the e-curve distributor you don't need to run an ignition box so you actually save some money by getting the more expensive dissy.
when you add up a msd pro billet dissy + 6al box + ign coil
and add up MSD e-curve dissy + ign coil
the e-curve comes out cheaper and if you want to later on down the road you can always add a box
Old 11-01-2009, 09:14 AM
okay i was gonna go with an msd distributor.. and i have stock heads but i am pulling the motor out and i am putting the edelbrock power package top end kit,451hp and 433 ft.lbs which includes intake, cam ,etc the whole kit.. is 600-750cfm carb enough for that
Old 11-01-2009, 09:18 AM
1966Tbird's Avatar
i would use a 750 for that and i would use a 750 mechanical secondary carb since you have a stick. what kind of heads was that package tested with because i would be suprised if stock e7 heads can produce that much power naturally aspirated
i would also talk to patrick at pro systems he will build a good carb for you, i wish i did that instead of using trick fuel
Old 11-01-2009, 09:30 AM
it comes with edelbrock heads to repleace the stock ones and also i have a c6 auto trans to put in it so what size carb would be needed? also they do not make an e curve distributor for the 351w
Old 11-01-2009, 09:55 AM
1966Tbird's Avatar
like i said i would talk to patrick at prosystems on monday 727-490-5717. their carbs are a little more expensive than a holley but are made to order and come pre tuned so all you need to do is bolt them on and go. They will be able to tell you better what size carb you need than me since they are experts who do this all day.
since they dont make an e-curve for the 351 i think you'll be alright with this dissy MSD Ignition 8478 - MSD Pro-Billet Street Distributors - Overview - SummitRacing.com just get a msd 6al box and blaster II coil, i like the taylor silicone wires they are really nice and you can cut them to length so they don't look sloppy
460 efi to carb conversion... Need help asap robert.royal Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 16 04-30-2015 08:02 AM
1989 5.0 EFI to carb swap ??? jdhudall Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 03-24-2015 12:10 AM
EFI to Carb Conversion - Pros & Cons? CircleRat Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 17 12-25-2013 07:43 PM
460 efi to carb conversion 97puller 1987 - 1996 F150 & Larger F-Series Trucks 6 09-06-2013 11:41 PM
92 f150 efi 302 conversion to 351w carb 92ford15089 Engine Swaps 2 06-06-2011 10:05 AM
Tags
1989, 302, aod, cable, carb, carburetor, conversion, distributor, efi, ford, ho, holley, swap, truck, tv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
