Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2009, 12:36 AM
Kennewick's Avatar
Kennewick Kennewick is offline
Kennewick is starting off with a positive reputation.
Carb Air Management System
Well I get kinda crazy but I have been studying Carb air flow for months and got real intreasted in cold air / ram air induction for my 73 fe. I have some pics here and hope not to bore anyone but it has been kinda fun progressing through this.
I first started with a stock cold air intake off of a 78 400 which by the way bolted right up to my 73. The hole in the radiator shell where it sucks air was not clean so I got out the skinny wheel and opened it up. also the plastic duct was not holding its shape so I made a custom bracket to leep it wide open. Then i just hooked it to the air horn with the standard cloth type duct. I didn't have a stove connection yet. It worked ok but I thought I could do better.
Next I hooked up a stove from a 66 Galaxy and increased the size of the connector duct to 3 " but I couldn't get a air tight fit for true ram air. On the highway a noticeable increase in power and gas mileage. Now I have gone to my next generation..
The stock mechanical actuator for the stove was a sticking piece of junk so Now I have gone to a filter housing off of a 80 302. This gave me a Vac operation, heat switch and bleed valve. This is the hot ticket plus the intake hole is the same as the FE. Then I found a good air horn with vac actuator but from a 76 300 6. The inlet was necked down.
Out came the skinny wheel and I cut off the neck down and fitted a intake fitting off a 68 390. So I have it all mocked up and cleaned up and primered tomorrow I will give it the final paint.
I am real happy and this baby will floww big time. It will be under full control and air tight for a good ram air effect. Sorry this is so long. Here is some pics of the new one.
  #2 (permalink)
Old 11-01-2009, 01:15 AM
Kennewick's Avatar
Here is that area where I have since cut open the scoop hole. Also the ram hole with the valve inside. Last look at the 302 airfilter housing inside it is smaller in diameter but I have a K&N for it and I liked the air diverter in it. The smaller size also makes it easyier to adjust the carb with the cleaner on it.
  #3 (permalink)
Old 11-03-2009, 11:00 PM
Kennewick's Avatar
Next step as I am moving along. I keep making improvements to the throat size and flow capability as I go. Next I will move to the improved pressure plenum I am building out of sheet metal. I just didn't like the stock one as it doesn't have very cleann flow and the new one will be 4" all the way to the carb. The carb air heater port is increased to 2.5 " the same size as the stove outlet so I can make it more air tight for better temp blending in winter. Here it is sitting on my new 2100 1.33v autolite carb. The spacer will be custom cut and over 2" thick. Dual ports into a open beveled plenum chamfered on the edges. Crap I can't wait to see what I can get out of this 360. Hey anything is an improvement.
  #4 (permalink)
Old 11-05-2009, 10:56 PM
Riderman Riderman is offline
Riderman is starting off with a positive reputation.
This is a joke...Right? Or, maybe Wiend, Holly, Eldelbrock may learn a few things here.
  #5 (permalink)
Old 11-06-2009, 10:38 AM
Kennewick's Avatar
Go have another beer!
  #6 (permalink)
Old 11-06-2009, 10:47 AM
Kennewick's Avatar
Hey have a beer!
  #7 (permalink)
Old 11-06-2009, 01:51 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE. Bear 45/70 has a good reputation on FTE.
All I can say is with my 1969 428CJ with Ram Air, when I removed the vacuum operated air valve and ran the thing open all the time the mileage went up almost 2 mpg. This may not sound like much except the car normally got 11 mpg and 13 was a major improvement (the 4.30 rearend was not a mileage maker option). That's almost a 20 percent increase. When I cold/ram aired my 1990 Escort GT the mileage increased 2 mpg (32 to 34 mpg) also but there was already a semi-cold air system on it to start with.
__________________
Bear 45/70 Gimp Racing <a href=http://i145.photobucket.com/albums/r206/Bear-45-70/Emoticons/icon_weelchairbb.gif target=_blank>http://i145.photobucket.com/albums/r...eelchairbb.gif</a>
“There are only two things stopping you, common sense and fear! And not much of the latter.”
  #8 (permalink)
Old 11-06-2009, 02:09 PM
Kennewick's Avatar
Quote:
When I get my truck out of prison, I will be able to fit the presure bopressure built up from the front of the radiator housing @60/70miles an hour) on it and hook it all up. This one will lie right down in there and not stick out and will flow wayyy more air with ice and cold weather control. If it doesn't work I'll rip it out, but it will. Nothing new just a few improvements. I hope to see some mileage increase on the highway. A 360 flows much less air than a 428CJ so I don't need as much to make an improvement. Any way it's my dime and my time. Havin fun ....wishin there was sun....
  #9 (permalink)
Old 11-06-2009, 10:46 PM
Bear, please dont put yourself in the same catagory as this mis-informed individual. You DO know how that circuit operates, right? If you know, then you know that your statement is impossible unless the valve was stuck closed. If the valve was open, as it should be after normal operating temp, removing it had minor impact on air flow, based on the rest of the breathers restrictive design. Ram air from a hood design has been proven not to be effective unless you are traveling above x miles an hour. Now someone is welding together pieces of stock breathers..I'll stop. This thead is a joke. No kidding. I suprises me that anyone can believe it, let alone try to prove it. Then slam a guy for pointing it out....geesh, yea, I'll have another beer and watch the show..
Rider
  #10 (permalink)
Old 11-07-2009, 01:31 AM
Kennewick's Avatar
Thumbs down
Drinking again??? Riderman your just following me from one thread to another. Are you insecure? Where I come from you would be tagged kinda creepy! I am not sure what your issue is. Anyone can see what I've done with my air cleaner. I have explained what I am doing with it. It is basic and I am just having fun with it. No brain surgery here. I am just a regular guy who would like you to go away. I have spent 30 years working in the field as a HVAC Refrigeration and building controls tech. I have Oregon and Washington State electrical licenses I am a Washington State Electrical Administrator and Electrical Board Certified Electrical Trainer. That is how I got my teaching job from experiance. I also support this forum and I enjoy my time spent here. Now get the hell off my case!
PS I also like Ford trucks. So shut your drunken beer hole!! Screw this forum you can keep your t-shirt and sticker since you never sent me one anyway and you can't moderate ass holes.
  #11 (permalink)
Old 11-07-2009, 01:39 AM
I was gonna let this go....but.......Dude you are a paraniod idiot. With all that training... your teaching at a prison...Those who cant, teach..Nuff said.
Dude, I just saw your PS. You need help, no kidding here. This is a forum for discusion, agree or dis-agree this is what helps people here learn. This paranoia about me chasing you around the FTE forum is in your head. I allway's learn from people's dis-agreements here on several topics...it brings discusion from several people and their point of views. There are a hundreds of people on this site with a lot of expierience to be passed on to us. With that being said...do NOT play the sycho game with me....I aint a liberal..
Rich
  #12 (permalink)
Old 11-07-2009, 01:52 AM
Kennewick's Avatar
You ****ing punk
  #13 (permalink)
Old 11-07-2009, 02:43 AM
Bear 45/70's Avatar
Quote:
Rider
Actually you really don't get it at all. I simply physically removed the flapper valve and it's vacuum motor. So you are wrong again. Also it is the cold air that helps, the ram part is not much with any short scoop. But it did work and was very effective. But you can't believe that because some moron said it ain't so. I lived with that car as a daily driver/weekend warrior and as a tow car after I got my second '69 428CJ. It did work and remarkably well too. The only joke is your insistence that this stuff doesn't work. Go sell your BS to someone who doesn't know better, I have the trophies to prove that what I did worked. Maybe if you knocked off the beer you might have a brain cell or two that still worked.
__________________
  #14 (permalink)
Old 11-07-2009, 02:56 AM
[quote=Bear 45/70;8116415]Actually you really don't get it at all. I simply physically removed the flapper valve and it's vacuum motor.
OK Bear, you are wrong! Your reading comprehension skill's need work. Removing that valve did NOT gain you 2 MPG. Take your face out of K's butt and explain it. None of this " it gained me 2 mpg because I noticed it, type post. Prove how! I gave you an out, but you chose to ignore it and slam me. That valve directed the air flow from the exhuast "stove" as you and "K" call it, mounted on the exhaust manifold until the incoming breather air temp, measured at the inside of thebreather, rised above a certain temp. (Yea, I know the temp) Then the valve opened up fully allowing ambient engine compartment air to be induced. Your saying by removing this valve, you gained performance and MPG through that restrictive breather? You and K, who doesnt get it? Other than your crap talk, did you even race a car? If you did, you were NOT a mechanic..shut up and drive... My daughter has trophys.. The Dyno talks.... Other than that, one should not slam another when one is clueless and has nothing but mouth to back it up. The beer thing was a joke...mayby not now though...
  #15 (permalink)
Old 11-07-2009, 03:09 AM
Bear 45/70's Avatar
[quote=Riderman;8116426]
OK bear, you are wrong! Removing that valve did NOT gain you 2 MPG. Take your face out of K's butt and explain it. None of this " it gained me 2 mpg because I noticed it, type post. Prove how! I gave you an out, but you chose to ignore it and slam me. That valve directed the air flow from the exhuast "stove" as you and "K" call it, mounted on the exhaust manifold until incoming air temp, measured at the breather. rised above a certain temp. ( Yea, I know the temp) Then the valve opened up. Your saying by removing this valve, you gained performance and MPG through that restrictive breather>> Who doesnt get it? Other than your crap talk, did you even race a car? If you did, you were NOT a mechanic..shut up and drive...
Oh so I'm a liar? Prove it nitwit or better yet just go back to the little pond you are from and talk big there. I know what it did and you weren't there. You just don't get it. I don't even care either. Your opinion has proven to be worthless. I actually have a bunch of trophies, from several differnt racing venues. I've even been a National Champion a couple of times and set some records even. Beside having been a professional mechanic, on both normal stuff and I was a paid race mechanic. But all I hear from you is other people's opinions and experiences. If you have no real world experience why not sit down, shut up and learn from those that have done something.
__________________
Tags
2100 , adjusting , air , carb , carburetor , circuit , cold , ford , increase , management , mpg , plenum , size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
