Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Maryland Chapter
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Maryland Chapter Join Chapter, Leader: jr32560
Is F-150 Still King?
  #886 (permalink)
Old 11-06-2009, 11:01 PM
racsantina's Avatar
racsantina racsantina is offline
racsantina is starting off with a positive reputation.
Okay, I'll admit it-I am lazy. Would someone let me know what atn stands for, when it is, and where it is? If the trophy is based on numbers, should I sign up the FFOs for an extra 2? I might even be able to get CD to sign up
__________________
Life is measured in minutes, but it is judged by moments
DNA makes relatives, but LOVE makes families
The gas pedal is the one on the RIGHT!
  #887 (permalink)
Old 11-06-2009, 11:18 PM
jr32560's Avatar
jr32560 jr32560 is offline
MD Chapter Ldr
jr32560 has a great reputation on FTE. jr32560 has a great reputation on FTE. jr32560 has a great reputation on FTE. jr32560 has a great reputation on FTE. jr32560 has a great reputation on FTE.
well the atn is the all truck nationals in Carlisle PA it in august
and I think it's a sign up for 2 people -if I'm not mistaken per vehicle -you will see a lot more about it as it comes closer to the time -think it's around the 8th or so
I'm lazy tonight my self
__________________
Junior Hardy-Md Chapter Leader
1990 F150 302
1995 E250 4.9
member of the Boy you ain't Right club #4
President of the crap shooters club
Join the Maryland Chapter click HERE
  #888 (permalink)
Old 11-06-2009, 11:19 PM
jr32560's Avatar
MD Chapter Ldr
okay guys I'm off here for the night -I'm pooped
see you guys tomorrow
__________________
1990 F150 302
1995 E250 4.9
  #889 (permalink)
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all
Wow...you guys have been busy tonight.
__________________
BPofMD - Bud
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB CrewCab Arizona Beige
2007 Arctic Fox 30' Fifth Wheel - 1997 Lincoln Mark VIII LSC
  #890 (permalink)
Old 11-06-2009, 11:24 PM
BPofMD's Avatar
Old-Timer
Guess I missed the party! Night all.......
__________________
BPofMD - Bud
  #891 (permalink)
Old 11-06-2009, 11:25 PM
Oldtrucknut7077's Avatar
Oldtrucknut7077 Oldtrucknut7077 is offline
Only at 42!
Oldtrucknut7077 is gaining momentum as a positive member of FTE.
evening bud, nite all
__________________
Scott: FTE Supporter, Mid-Atlantic/PA Chapter Member!
1998 EXPEDITION E.B. 5.4L/1998 F150 Lariat 5.4L/2004 EXPLORER E.B 4.6L
Never take life too serious, no one ever gets out alive!
2010 MIDATLANTIC MEET, CARLISLE, PA ALL TRUCK NATIONALS AUGUST 6--8, 2010, CLICK HERE
  #892 (permalink)
Old 11-06-2009, 11:26 PM
ford to the bone's Avatar
ford to the bone ford to the bone is offline
ford to the bone
ford to the bone is starting off with a positive reputation.
nite jr buddy
__________________
John mills
1977 f250 hiboy
1994 f150 4x4
Maryland chapter member
  #893 (permalink)
Old 11-07-2009, 01:44 AM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
owned by fords
dustybumpers is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by ownedby2labs View Post
well the dummy befor me used that orange sealing crap instead of a gasket seen it as soon as it went up on the lift i got home rechecked it had my boy give it some gas and the bolts dont look all that tight its where the trans and transfer case meet so im looking at some labor for thejob and i figure while its there we will do the rear main seal too
there's a paper seal in there, you can split the transfer case, and the trans apart without removeing the trans. clean everything real well, then use permatex form a gasket, not blue glue, or red. they won't work. the form a gasket works fine. I also put axels back in with it, as well as rear covers, and haven't had a problem with it.back seal at the driveshaft should be done at this time too, put a little grease inside the seal to keep it from tearing when 1st drivin until the oil splashes in there.be careful how much you tighten the transfer case when you put it back on, they strip/ break easy. that's what happened to Dave's big bronco when he finally gave up on it, and cut it loose
__________________
Charlie
  #894 (permalink)
Old 11-07-2009, 02:06 AM
owned by fords
ok it the trans then bolts into some housing that has the trans mount then transfercase
that piece is called an adapter. there is a paper gasket on both sides where it bolts up. see previous post on how to fix it
Quote:
Originally Posted by tin-man View Post
I look at it this way, JR and Arlene are there it has to be a blast!!
don't forget George is there as well. [Jay Leno in disguize]
Quote:
Originally Posted by jr32560 View Post
so YOU gonna try and come this year Tin man? you won't regret it believe me
if you don't laugh I'll check your pulse and give ya CPR
me thinks you better watch out David, He'll do the mouth to mouth part, while your still upright.
so theres no trans fluid there unless the seal is bad is what you are telling me
trans fluid on one side, gear oil on the other. like the end of a big oil pan
2 per car. Janet and I had to pay, but didn't count because we weren't there before 9:00
__________________
Charlie
  #895 (permalink)
Old 11-07-2009, 06:45 AM
jr32560's Avatar
MD Chapter Ldr
good morning all-it's a cold 27.7 down in PF-
__________________
1990 F150 302
1995 E250 4.9
  #896 (permalink)
Old 11-07-2009, 07:04 AM
jr32560's Avatar
MD Chapter Ldr
Quote:
thanks Charlie I think that was what he was looking for-great info
__________________
1990 F150 302
1995 E250 4.9
  #897 (permalink)
Old 11-07-2009, 07:26 AM
97nukeford's Avatar
97nukeford 97nukeford is offline
Nebraska Chapter LDR
2006 Ford F-250
My Garage
97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of
Good morning Junior and the Maryland gang!
__________________
Pat W.
Nebraska Chapter Leader and Official #2 Slackmaster!
2006 F-250/ 1997 F-150/1967 F-100
1967 F-100 Project
GO HUSKERS!!
CLICK HERE TO JOIN THE NEBRASKA CHAPTER!
  #898 (permalink)
Old 11-07-2009, 07:39 AM
tin-man's Avatar
tin-man tin-man is online now
SC Chapter LDR
1975 Ford F-250
My Garage
tin-man has a great reputation on FTE. tin-man has a great reputation on FTE. tin-man has a great reputation on FTE. tin-man has a great reputation on FTE. tin-man has a great reputation on FTE. tin-man has a great reputation on FTE.
Good Morning Maryland!! JR and Pat
__________________
David
1975 F-250 Custom High-Boy
Join the SC chapter HERE
Master Slacker#14
True compassion puts love in action
  #899 (permalink)
Old 11-07-2009, 08:09 AM
Only at 42!
morning MD
__________________
  #900 (permalink)
Old 11-07-2009, 08:52 AM
ownedby2labs's Avatar
ownedby2labs ownedby2labs is offline
ownedby2labs is starting off with a positive reputation.
Yup that is what I was looking for thatnks alot for the info I got a hayns book and all that says is ya it's a trans lol
__________________
Adam-cordinator balt county
1978 F150 4x4
Tags
34 , 41 , 90 , attack , brands , carlisle , clubs , crapshooter , dos , ford , internet , pa , ranger , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
