whats up NY? Neil, we just did hose testing today. 2000' of 5" supply line off 2 pumpers. man that sucked to repack.....
That does suck and fortunately we do not have any 5" LDH. If we need to lay in we run 2 - 3" lines and then bring them into a siamese at the steamer.
All of the mutual aid departments around us have 5" LDH and they are usually supplying us if we are at a structure fire. Then again, we can draft with 1500 gpm and run 2 - 3" into a 2- 2 1/2" to 5" adaptor.
__________________ Neil a.k.a. Tiny...... Official #3 Slackmaster & Pyroslacker Extrordinaire 2001 F 150 XLT 4x4 & 2008 Edge AWD SEL
Well as you can tell I am home from the banquet. The food was great, had the evening to spend with friends and also had a chance to unwind with them also. The bar had Sammy's Oktoberfest on tap
oh. thats interesting, Ive never heard of that before. we were using 4", but we switched to 5" a couple years ago. when we were doing the test, we ran 3" pony line from the hydrant to the rig.
__________________
Brian L.ask for facebook
1994 F150 XL 2wd standard cab short bed 300 I6
E4OD trans 8.8 rear towing package with 3/4 ton springs linex bedliner safety rack cab guard
210,000+miles http://www.youtube.com/user/W12CO1
Yeah that is the way that we do it. 5" LDH is STUPID expensive. Something around I believe $800 to $1000 per 50'. It was bad enough that I had to replace 2 - 50' lengths of 1 3/4" which ran around $200 per length
ouch. luckily all our 5" on these rigs passed. one rig's hosebed was specd just right to fit 4", but when we went to 5", we had to take all the 2 1/2" and a divider out of the hosebed just to fit the 5". and everything in the fire service is expensive lol
__________________
Yeah it is. An inexpensive set of turnout gear (coat, bunkers, boots, helmet, gloves, hood and suspenders) runs right aroun $1700 - 1800 per set. Our gear is black and once it is heat stressed it will turn red. Any spot of red, it needs to be replaced because it does not meet NFPA or OSHA requirements. A cheap rescue on a two door commercial International chassis..... $225 - 250K. A cheap pumper.... $180k and this does not include any equipment.
Most of the departments in our area run 4", mine included. There are 2 that we work with that run 5". Oh, and you're right.; if it has Fire or Rescue in the name somewhere, they get to charge you a minimum of 3 times what the item is really worth.
__________________
Brad
2003 F-250 Lariat Supercab 4x4 6.0L PSD, Fumoto, Updated HFCM Plug, DieselSite Bypass Coolant Filter, 22" Wiper Blades, more to come...
2008 Taurus X Limited AWD w/ a Fumoto (The Wife's Family Truckster)
Quote:
You haven't lived life until you've done 110mph in a Yugo
You mean to tell me that your hose testing company didn't repack it for you? That does suck. The company that we use takes it all off and repacks it when they are done. The hose beds look immaculate when they're done.
__________________
Brad
__________________ 2000 f350 v10 lariet-A.R.E. cap front mounted hidden hitch SCT -X2 5 STAR TUNING-S&B CAI 2009 wheels and tires-superlift leveling kit firestone air bags-bilstein shocks
__________________
Shawn Official #17 Slackmaster!
The Republic was not established by cowards; and cowards will not preserve it ... This will remain the land of the free only so long as it is the home of the brave.Elmer Davis
