Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 11-02-2009, 10:11 PM
Gobstopper909's Avatar
Gobstopper909 Gobstopper909 is offline
AMERICAN & A
Gobstopper909 is gaining momentum as a positive member of FTE.
glad to hear you got it out. i tried the "old faithful" trick with 2 gps and no dice. but im sure someone has gotten lucky with this problem in a 7.3. rog, becareful with that carpet idea... we've got almost 400 psi in there. i used 3" angle just to be safe and held the rpms up pretty high when i tried. mythbusters should try it!!!
  #17 (permalink)
Old 11-02-2009, 11:24 PM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
Talking
Bear in mind that I have yet to experience a stuck GP. I was just passing along what I had been told/read. I further think that I had read on another forum where the valve cover was replaced prior to high revs. Can't recall if it produced a large dent or a hole or both when it finally let loose.
Either way what ever methodology is used I'm sure it will be better than closing the hood.
Rog
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
  #18 (permalink)
Old 11-02-2009, 11:52 PM
AMERICAN & A
Quote:
Rog
ha ha maybe a start to a ram air?
  #19 (permalink)
Old 11-04-2009, 06:22 PM
bill11012's Avatar
bill11012 bill11012 is offline
bill11012 is gaining momentum as a positive member of FTE. bill11012 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Copedawg View Post
In the military when the GP broke off (not dropped but stuck in the hole) in the HMMWV's we would just crank it and 9 times out of 10 that baby went airborne ALL THE WAY! Would anyone recommend doing that in a pinch?
I tried that on my IDI and it did not work.
Used vice grips and it came right out.
__________________
My V10 will out pull your PSD any day of the week.*
*If you have a stock 7.3 with 3.73s or 3.55s and 4 speed auto. Test must be at sea level
I will smoke the 6.0,6.4 and new 6.7 after I do the twin turbo mod.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
