Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 10:21 PM
Danny D's Avatar
Danny D Danny D is offline
Danny D is starting off with a positive reputation.
Pulling older engine, what repairs to do?
I have a 272 in a 1957 truck with at least 50,000 miles on it. I want to pull it out and put it into another truck. This engine has not been run for ten years. It did manage to start and run with only a new battery and a little fresh gas mixed in with the 10 yr old gas in the tank. I cleaned the carb and put in a new kit, replaced the spark plugs and use new gas. It runs a lot better. the old plugs looked like all were firing. No smoke to speak of out the tail pipe. It does smoke out the oil fill cap and the vent tube pointing down on the left side. Stuck rings? blow by? valve seals? I am planning on cleaning it up outside, replacing some gaskets, removing the oil pan and valve covers and do some cleaning on the inside.What else should I do when I have it pulled out? I dont want to put a lot of $ into it. One guy said rework the valves to take modern gas. This engine is going in a work truck, not for show. What would you suggest? Thanks, Danny
  #2 (permalink)
Old 10-31-2009, 10:37 PM
Colt 45 Colt 45 is offline
Colt 45 is starting off with a positive reputation.
Dan, changing the valves sounds like the thing to do. ( unleaded gas ) Other then that cleaning the motor should do it... colt 45
  #3 (permalink)
Old 11-01-2009, 01:01 AM
flipklos flipklos is offline
flipklos is starting off with a positive reputation.
I would run her good and hot with some seafoam in the oil for a few hours. That may help clean up any gummed up oil passages. Then use a reputable 10-30 or so oil. I use rotella. As it has ZDDP which is neccisary for a mechanical flat tappet engine.
(If anyone wants to argue ZDDP, botique oils, synthetics, or any other thing, please start a seperate thread and let us argue that there. I think we can simply advise the guy on getting the engine running in good order.)
Also, I will second the heads getting done for unleaded. A three angle and some hard seats will put alot of life in an old engine. Check the rockers for excessive wear and play while your at it.
Good luck.
  #4 (permalink)
Old 11-01-2009, 04:02 PM
Flipklos, I agree. I'm not really to sharp at this stuff so I'm learning... colt 45
  #5 (permalink)
Old 02-22-2010, 10:29 AM
MBDiagMan MBDiagMan is offline
MBDiagMan is starting off with a positive reputation.
If it were me, since the engine is now running, I would put it in with oil like Chevron Delo or Shell Rotella as flip said. Run that sucker and do a few short oil and filter changes, like a couple in about 500 miles, THEN evaluate the engine. If it were running good before, I think that it will run now. After the first of these quick oil changes I would set the valve lash.
__________________
Doc
ASE Master
1964 Galaxie 500 Fastback
1978 F150 Shortbed 4X4 that I bought new.
2000 F150 RC, Flareside, 4.6, 5 speed 4X4
2006 Mustang GT, 3 valve 4.6, 5 speed manual
Other vehicles of blashemous make other than Ford
  #6 (permalink)
Old 03-08-2010, 08:31 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 is starting off with a positive reputation.
Howdy,
Just clean up the outside, change the oil and run it as is.
If you think you need a valve job then do it. If it runs fine, just use it. I ran my 57 292 for many years on "unleaded" with no problems. Run it until it needs a valve job, THEN do it.
Put any 15W40 oil in it and change it at a regular time. (I.E. 5000 miles, 6mo etc) Use the truck.
Cheers,
Rick
__________________
1955 F-600 // D I S C L A I M E R: No animals were injured while test driving my F-600 except the ones I RAN OVER INTENTIONALLY!!! (RESISTANCE IS FUTILE) 73 de Rick
Tags
engine , engines , f150 , pulling , seafoam
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
