Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 11:14 PM
fredo181 fredo181 is offline
fredo181 is starting off with a positive reputation.
Speedomter in-op, Need Help
I have a 2001 Ford E-450 with a 6.8 L Automatic. The speedometer works intermittent and when it does work it only will go up to 40MPH. Even on the highway it stays on 40MPH. Sometimes it wont work at all.
Ive been told there is a Vehicle speed sensor in the trans.and the rear end housing. Is there two of them? I also heard the one in the rear end is for the ABS?
  #2 (permalink)
Old 11-01-2009, 10:08 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all
I believe the one in the rear does it all, for the abs, the cruise, the speedo and the road speed reference for the tranny computer. Do you have any other error lights? Is the tranny shifting ok?
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 11-09-2009, 10:36 AM
Quote:
I just replaced the sensor in the rear diff. and the speedo is still not working?
I don't have any error lights and my transmission shifts a little rough.
Anything else I can check?
  #4 (permalink)
Old 11-09-2009, 10:47 AM
marktaylor marktaylor is offline
marktaylor is starting off with a positive reputation.
speedometer is very necessary in the car...it shows the speed of your car..if it is not working give it for repair...
  #5 (permalink)
Old 11-16-2009, 10:45 PM
ReadOrDie_WoW's Avatar
ReadOrDie_WoW ReadOrDie_WoW is offline
Import Killer
ReadOrDie_WoW is starting off with a positive reputation.
for the shifting rough part, first thing I would do is check/flush the tranny fluid. only other thing I can think of off hand is that your speedometer cable is wearing out not too bad a fix, just takes some time, and prolly needs changed, that or the speedo itself is wearing out, I would go to a junk yard and pick up one just too make sure of this. Also, I know that for the 92-98 models, (not including the 97 and up 150) there is a problem with the wiring harness getting caught inside the steering column and wearing through, causing stuff to quit working (currently I have a 94' that I think this is happening too, cause I have no illumination or cruise control myself) If all else fails you can check it or go to ford and see if they might be able to think of a quick solution for this (if its a common problem that is)
__________________
94' Ford F-250 7.3 IDI Custom "Baby Blue"-08' Dodge Ram 1500 4.7 Custom "the Grey Ghost"
"Because life's to short to drive a chevy."~RoD
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
