for the shifting rough part, first thing I would do is check/flush the tranny fluid. only other thing I can think of off hand is that your speedometer cable is wearing out not too bad a fix, just takes some time, and prolly needs changed, that or the speedo itself is wearing out, I would go to a junk yard and pick up one just too make sure of this. Also, I know that for the 92-98 models, (not including the 97 and up 150) there is a problem with the wiring harness getting caught inside the steering column and wearing through, causing stuff to quit working (currently I have a 94' that I think this is happening too, cause I have no illumination or cruise control myself) If all else fails you can check it or go to ford and see if they might be able to think of a quick solution for this (if its a common problem that is)
__________________
94' Ford F-250 7.3 IDI Custom "Baby Blue"-08' Dodge Ram 1500 4.7 Custom "the Grey Ghost"
"Because life's to short to drive a chevy."~RoD
