Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 10:26 PM
f350fan1993 f350fan1993 is offline
f350fan1993 is starting off with a positive reputation.
HELP!!!
Today I installed an injector seal kit on my truck that was running like poop when cold but would run great after it warmed up. Here's the kicker, after I installed it, guess what, IT WON'T START! I've even tried starting fluid, it would run for a second then dies. I dont know if I did something wrong, or am I missing something. I'm desperate because this is my only vehicle, it's a 93 7.3 idi with a banks turbo, thanks in advance!
  #2 (permalink)
Old 10-31-2009, 10:30 PM
87crewdually's Avatar
87crewdually 87crewdually is online now
87crewdually is starting off with a positive reputation.
Sounds like your air bound. loosen the injector lines and crank it til just fuel is squirting out. Then tighten down the lines and it should start right up.
__________________
87 CCD, 6.9 Banks Sidewinder turbo & ARP studs, fresh pump & injectors, str8 Pipe out the side, worked C-6, 4.56R&P & Laycock/GearVendors Overdrive
  #3 (permalink)
Old 10-31-2009, 10:36 PM
I'll try that as soon as I recharge my batts because I manage to run them down, also it would sputter, every so many cranks. I'm at a loss. I feel like I should have just left it alone, because it was running. By the way, thanks for the quick reply
  #4 (permalink)
Old 10-31-2009, 10:39 PM
If it ran before it will run again. Don't get discouraged. Also if your batts were real low it may not of been opening the fuel shutoff solenoid on the injection pump. Charge them up and crack the lines loose as I described. Should light off once the air is out.
__________________
  #5 (permalink)
Old 10-31-2009, 10:40 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
1993 Ford F-250
FORDF250HDXLT is starting off with a positive reputation.
when you take off injectors,and the fuel flows back.how far back does it go?
i mean,is there a valve in the fuel filter,to keep it from draining all the way back to the tank?
if there's not,he's gunna want to be sure his fuel filter is full first,otherwise that's a load of cranking to get that filled.
ahhh,the electric fuel pump conversion.i can see this is so important lol.
__________________
1993 F250 Heavy Duty 4x4 XLT, regular cab, two tone with red interior, 444CID/IDI/NA International Diesel, E40D auto, 1356 BW manual shift TC, Dana 50 TTB front/Ford-Sterling 10.25 2nd-gen full floater rear with 3.55:1 gears.That's stock.See my garage for mods. 47k original miles. Carfax clean w/last OR 29,200 in '06. Not yet on the road. Brand-new to me.
Real Trucks Don't Have Spark Plugs.
  #6 (permalink)
Old 10-31-2009, 10:41 PM
Thank you very much, I will post as soon as I get it running (granted that I can get it going).
  #7 (permalink)
Old 10-31-2009, 10:44 PM
Well I managed to get the fuel to squirt all the way up my arm at the filter, so I would assume its at the lines, or at least I hope it is!
  #8 (permalink)
Old 10-31-2009, 10:45 PM
I've had injector lines off and the filter never drained back on me. But it wouldn't hurt to verify that it is full.
__________________
  #9 (permalink)
Old 10-31-2009, 10:47 PM
I really appreciate the help, mainly because my wife is teating this like I did it on purpose!
  #10 (permalink)
Old 10-31-2009, 10:52 PM
1993 Ford F-250
oh good.
shouldn't be to hard from there then/especially with new lines that wont be leaking anymore.
charged up batteries and she's gunna start right up after following post#2 instructions.
hopefully this fixes your cold running problem.
__________________
  #11 (permalink)
Old 10-31-2009, 11:01 PM
I failed to mention that one of my injectors managed to come apart, amazingly I was able to put it back together. I'm thinking though one dead cylinder shouldn't keep it from running should it? It should miss, but start if my reassembly didn't work, right?
  #12 (permalink)
Old 10-31-2009, 11:09 PM
I guess it shouldn't matter
  #13 (permalink)
Old 11-01-2009, 09:57 AM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is online now
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
It will probably have a miss, but should still run.
You may be in line for new injectors.
Caution on cranking the engine, 20 seconds max, 2 minutes cool down time before cranking again.
Starters overheat and are rather expensive.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #14 (permalink)
Old 11-01-2009, 01:55 PM
Got the ole' mule runnin again, I'm going to go get another injector, but I have a problem. Does anyone know how I can get the other half of the broken injector out? I cant seem to get it, all itdoes is spin around in there.
  #15 (permalink)
Old 11-01-2009, 07:18 PM
Got the old one out, new one in, now she runs like a new truck again. Now the last of my problems is hopefully an answer away. My glow plug controller has died, my question is how would I wire a toggle switch to the relay to heat the glow plugs. Thank you guys for helping me get my truck running again, I'll figure out a way to repay all of you for your help.
Tags
1356 , case , transfer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
