Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 07:10 PM
rlester rlester is offline
rlester is starting off with a positive reputation.
97 Explorer, OD not working and shifts funny.
I just bought a 97 explorer from my friend with the X engine and code D transmission. The overdrive quit a year ago, and its also not shifting right if you drive agressively. If you accelerate slowly, it seems to shift fine, but otherwise you have to let off on the gas to get it to shift.
I was looking into getting another explorer for parts, but it had a toasted trans.
I read on here about the valve body gasket replacement procedure, and I wonder if this might be the problem? Did he do damage by driving it like this? Should I just look into a rebuilt trans?
He already had the trans flushed to no avail.
Thanks.
  #2 (permalink)
Old 11-01-2009, 01:55 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar is starting off with a positive reputation.
Uhm, this should have been in the shop a year ago. Hard to say if any damage has been done or not, but when the trans stops working correctly, the best rule of thumb is to stop driving it until the problem is resolved. Otherwise slippage and deteriorating crud can damage the rest of the trans. OD not working could be from a lot of sources. Valve body issues is one, old worn out fluid can also do it. There are also sensor issues that can cause OD to be disabled. What codes are stored in your computer?
  #3 (permalink)
Old 11-01-2009, 09:04 PM
I know what you mean by it should have been in the shop, but I didn't own it at the time. He did take it to the dealer, but they didn't have a clue what was wrong, and they just flushed the system.
As for the codes, there was an EGR code, and another one about a solenoid failure, but I cleared them, and put a tank of gas through it without the light coming on. It runs great other than the shifting problem.
  #4 (permalink)
Old 11-02-2009, 12:37 AM
You need to take it to a qualified and locally owned trans shop. If the shop has a flush machine or they recommend flushing it, find another shop. Flushes seem to cause more problems than they fix.
If they do some pressure tests, they can see what is going on inside and determine whether this is a mechanical or hydraulic problem.
Tags
explorer , ford , od , working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
