Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 06:46 PM
keg keg is offline
keg is starting off with a positive reputation.
hydraulic rocker clearance 351 Cleveland
Hi I am rebuilding a 79 F250. in the process I am fitting alloy heads and roller rockers with hydraulic lifters on a Stage 3 cam can anyone tell me the gap to set the rockers at when cold. so when I start the motor and the lifters pressurise they will not be over tight
thanks
http://images.ford-trucks.com/forums...ies2/thumb.gif
  #2 (permalink)
Old 11-11-2009, 05:34 PM
IB Adrian's Avatar
IB Adrian IB Adrian is offline
Administrator
2005 Ford Falcon
My Garage
IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation
Thread moved to 335 series forum
__________________
Adrian
FTE Guidelines
Quote:
Originally Posted by WhëëlMå1
... he is a mouthy broad.
  #3 (permalink)
Old 11-11-2009, 06:11 PM
grclark351 grclark351 is offline
grclark351 is starting off with a positive reputation.
what type of adjuster do you have, is it a 7/16" screw-in stud?
if so you could use anywhere from 1/2 turn(.025" preload) past zero lash to 1 full turn(.050" preload) past zero lash and be fine. generally the less preload you use the faster and higher the engine will rev all other things being equal.
there's a lot about preload in the archives, 'search this forum' for 'lifter preload' and read all about it
Tags
351 , rockers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
