Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 05:47 PM
JHoffman93's Avatar
JHoffman93 JHoffman93 is offline
JHoffman93 is starting off with a positive reputation.
#7 Injector line
I have begun to have the dreaded hard to start issue with my truck. I was checking things out under the hood and I noticed that the right hand bottom injector line coming off the IP is wet with fuel. Two questions: Could this cause a hard starting issue and how do I tighten the line? There must be a trick that someone knows about. Thanks.
__________________
Aircraft Mechanic, Wichita Citation Service Center. Proudly burning B100 from Healy BioDiesel in my 2001 VW TDI and 1993 F250 Ext. cab IDI 2x4 with a 5 spd manual 3.55 gears.
  #2 (permalink)
Old 10-31-2009, 06:21 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
There is a rubber seal under the cap nut at both ends..... they can be found at Diesel repair shops by applicable fuel line OD. 5/16 ID for the 2 on that line, 3/8 ID for the 1 on the lift pump to filter header connection. Do not over torque the seal.......just seal it.
__________________
93 F250 SC 4x4 E4OD 355LS
  #3 (permalink)
Old 10-31-2009, 08:42 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold
Quote:
What are we talking about here? The injection lines on my truck are metal, with a weird metal flare on the end, and the mating ends on the injector and the injection pump are both metal. The nuts compress the metal flare into the metal seat of the injection pump fitting and the injector.
I would try to tighten the line on the pump, but you may have to custom bend a wrench or get creative to get at it to tighten it. If you just can't get it, take a deep breath and take some of the other lines off to get to it.
If it doesn't stop leaking, I would suspect it's cracked like my #1 line did. Check along the line, and there should be some clamps holding all the lines together. If someone has taken them off, then I bet the line is cracked.
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 10-31-2009, 10:41 PM
JHoffman93's Avatar
I may have to take an old 5/8" wrench to work and heat it up with the torch. Problem is it may take me several tries to get it right. I don't want to mess with the ones that are not leaking for fear I will induce a leak in ones that currently are not leaking.
__________________
  #5 (permalink)
Old 11-01-2009, 09:02 AM
Sorry about the confusion above....... i read the problem too quickly. I was refering to the Filter header to IP line.
There can be cracks in the hi pressure line cap nuts from over torquing, aligning the nipple in the fitting is required so finger tightening is possible.......damage can be done to the line nipple face if not aligned correctly and pulled tight with a wrench.
__________________
Tags
69 , cap , injector , seals
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
