Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 11-01-2009, 11:22 AM
Knox's Avatar
Knox Knox is offline
Knox is starting off with a positive reputation.
why would the glow plugs cause the starter to go?
  #17 (permalink)
Old 11-01-2009, 11:37 AM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is online now
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
Excessive cranking since the glow plugs are not working.
Diesel fuel takes 500 degrees in round numbers to auto ignite.
Glow plugs raise the cylinder temperatures and makes that happen faster than just cranking the engine.
Yes it may start if you crank the engine for 15 or 30 seconds without glow plugs, but with working glow plugs the engine will fire in less than one full revolution.
In warm temperatures, glow plugs save the starter.
In cold temperatures, they make it possible to start the engine.
Think outside air temp to 500 degrees in one compression stroke.
Even at 21.5 to 1, that is a lot to ask from the engine which is also at outside air temp.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
Tags
03 , 73l , diesel , e350 , fluid , ford , idi , motorcraft , speed , start , starter , starting , truck , works , zdii
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
