Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 04:46 PM
yeahbuddy24 yeahbuddy24 is offline
yeahbuddy24 is starting off with a positive reputation.
I need the pros ADVICE!!
Hello. There is a 1976 ford f250 camper special for sale in my area. This truck was originally 2wd but has been converted into a 4wd. He says it runs strong and will climb up anything now. My worries are is it possible to do this converson and still have the truck function properly? meaning will i drive down the road straight? i dont want to get something with lots of problems. He said they did a good job on the converson but i wanted some advice if this converson is lagit? Thanks!! Steve
  #2 (permalink)
Old 10-31-2009, 04:57 PM
CrazyAirman's Avatar
CrazyAirman CrazyAirman is offline
CrazyAirman is gaining momentum as a positive member of FTE.
Sure, if it's done right, should be great. Drive it tho, and you should be able to feel if its "right" or "hacked"
__________________
I painted the dang thing camoflage, now I cant find it!!
74 F100 4X4 Grump-a-saurass
WAY more guitars than talent
  #3 (permalink)
Old 10-31-2009, 09:16 PM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all
Hek, just post some pics of the front suspension. Idealy the spring hangers, or coil buckets, radius arm mounts or shackles, and the most inportant,,,,steering. We can tell you from a picture if it worth a hill of beans or not.
  #4 (permalink)
Old 10-31-2009, 09:23 PM
cougarshaman's Avatar
cougarshaman cougarshaman is offline
cougarshaman is starting off with a positive reputation.
There are way too many dentside 4x4's out there to buy some redneck hack job.
You're right to be cautious.
Pics will tell the whole story.
  #5 (permalink)
Old 10-31-2009, 10:10 PM
Drac Drac is offline
Drac is starting off with a positive reputation.
In my mind, there are only two ways to convert a 2wd to a 4wd.
1. Put a 2wd body on a 4wd frame. NO Problem, if done very clean. All the parts are ford OEM, fixing and find parts is pretty easy.
2. Hack a front axle and transfer case into a 2wd frame. I wouldn't touch it. Nothing worse than a basket case nobody wants.
It is all about what frame it has, there is a big difference between them. Like Cougar says there too many good 4x4's out there.
__________________
'65 F-250 4x4 w/ '76 460 & 514 in a 1900lb Drag Rail
Under construction: "Black & Bad" '79 F-150 4x4 -351w, 435np, 205np, TFS Twisted Wedge heads, Speed demon, Comp 4x4 extreme cam, edelbrock RPM AirGap, NOS Powershot, detriot locker, w/a '73 grille
  #6 (permalink)
Old 11-01-2009, 12:21 AM
Riderman Riderman is offline
Riderman is starting off with a positive reputation.
On the other hand, there are people like F350 and others on this site that could convert it better than factory. Alot of this is plug and play, some of it is not. Post a few pic's of the drive train and front end.
  #7 (permalink)
Old 11-01-2009, 01:59 AM
grandmas77f150's Avatar
grandmas77f150 grandmas77f150 is offline
grandmas77f150 is starting off with a positive reputation.
Checking his work on the front suspension is a must.
If he'll let you, do a test drive around the area, see how it drives for yourself.
Note: If you want to do a full resto, you'll run into major work, converting back to 2wd to make it original. If this is for play and daily driving, its up to you.
__________________
01 Ranger Edge 4x4 Supercab
77 F-150 4x4 351M "Grandma's Truck"
77 F-250 4x4 400M - Work in Progress
  #8 (permalink)
Old 11-01-2009, 08:22 AM
Quote:
Good point.
I would only rebut (not to argue, but just to clarify what I mean by "redneck hack job") that people like F350 are few and far between.
The number of people out there who believe that welding is melting mig wire on a piece of metal, rebuilding a carb is installing a new float and needle/seat assembly along with hosing it down with cleaner, etc are copious. There are a LOT of people out there who don't understand the importance of structural integrity when working with frame members and hybrid components. This is where intelligence, experience, and more than basic knowledge come into play.
Yes, a lot of it is plug and play. But, the crucial parts are not and require expertise to do properly. Lots of people watch Jesse James on tv and think what he does is easy because he makes it look easy. Fabrication is art and science.
Imagine buying a cobbled together 4wd conversion and having the welds fail as you're heading into a curve in the winter with snow on the ground and your kids in the truck beside you.
This is why it's crucial to look before you leap on anything that's had fabrication work done to it by anyone who doesn't have a shop, reputation, and a list of credentials and references.
Living in the Southern Appalachians, I've seen a number of home built rock crawlers break up and pop apart in Tellico or similar spots, and I've seen home built stuff that looked like a pro chassis shop built it.
Call me a curmudgeon, but if someone wanted to sell me a conversion they'd have to work hard to make me believe they knew what they were doing enough for me to plunk down my cash.
Probably the funniest and best known example of poor workmanship:
  #9 (permalink)
Old 11-01-2009, 08:35 AM
mark a.'s Avatar
mark a. mark a. is online now
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
I would look it over very close. Have him drive it down the road while you follow watching to see how it tracks. If it all looks ok, buy it if the price is right.
__________________
'79 F250 13" lift 42" Super Swampers
  #10 (permalink)
Old 11-01-2009, 09:48 PM
Thank you all for the advice, as i do not want to buy a hack job either. Here are the only pics i can get now. Mind you i have the exact same pickup with the exact same 2tone paint job but it a 2wd. i am going to take the wood bed of the 4wd F250 and swap it out with my 1974 Ford f100 bed (it in good conditon). I want to use the F250 4wd for my daily driver for the most part. He says the truck is solid and runs great. I know the pics are not the best but if you can see anything that may be a red flag or any advice let me know Thanks......P.S. i could not for the life of me find out how to get these pics to post in the thread. i could not find the attatch button?? hope it worked
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
