Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 and Newer F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
The 2009 and Newer F150 Discuss the new 2009, 2010 Ford F150 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 03:23 PM
ford_07 ford_07 is offline
ford_07 is starting off with a positive reputation.
pics of hauling hay
hey i finally got some pics of hauling hay thought i would share
  #2 (permalink)
Old 10-31-2009, 06:25 PM
johnwill johnwill is offline
johnwill is starting off with a positive reputation.
Those are great shots ! Love to see our rigs being used as trucks !!!
Nice rig (including the trailer) !
  #3 (permalink)
Old 10-31-2009, 07:16 PM
Vinford's Avatar
Vinford Vinford is offline
1979 Ford F-250
Vinford is gaining momentum as a positive member of FTE.
Nice pictures.
Where abouts are you?
__________________
Ken
2002 F-350
Foil delete , Edge Ev
1979 Ford F-250
1996 Ford F-250
Plus a few more ....................
  #4 (permalink)
Old 11-01-2009, 03:57 PM
montecarlo31 montecarlo31 is offline
montecarlo31 is starting off with a positive reputation.
I'm guessing you were somewhere around 14K to 17K lbs with just the trailer (trailer at 4500 lbs since it appears to be a powered tilt deck, 1K lbs a bale if the person running the tractor knew what he was doing and it was dry). I must say that, aside from back loading the trailer the truck has very little squat for the load.
I pulled 9 bales on a similar trailer w/ our 07 expedition EL 4x4. It got going no problem but even with good trailer brakes it took a good bit of brake power to slow the load.
Hope the trailer brakes worked.
  #5 (permalink)
Old 11-01-2009, 04:45 PM
the trailer and truck were awesome!! i have to say that the way these trailer brakes work i had to set the gain quite a bit higher than i thought because of the way they come on, but all in all it was fine. (it was a power tilt deck, although it didnt work like i planned and still had to push the bales off by hand)
  #6 (permalink)
Old 11-01-2009, 05:20 PM
Chris Anchor's Avatar
Chris Anchor Chris Anchor is offline
Chris Anchor is starting off with a positive reputation.
Quote:
I would say less then 14K - 17K as those bales are grass hay and loose. I would give them about 600 lbs each if dryer plus trailer about 10K-11K down the road. Still these 2009 F-150 pull the weight just as good as any F-250 gasser does. Between the electronics and new frame, it works to give you that little extra. Chris
__________________
2009 F-150 XLT 4x4 5.4 Regular Cab 8' box 3.73 rear/max tow/8200 lbs/built in controller-One towing/ hauling machine
1996 Mercedes E300 Diesel Sedan & 1984 Mercedes 300GD "G" Wagon 4x4
  #7 (permalink)
Old 11-01-2009, 05:51 PM
Vinford's Avatar
1979 Ford F-250
You look like your in the Cariboo somewhere?
__________________
Ken
2002 F-350
1979 Ford F-250
1996 Ford F-250
  #8 (permalink)
Old 11-01-2009, 08:00 PM
Quote:
i agree they look loose but wet. I'm not expert on those loose bales. I agree that the Supercrew 6.5' bed will handle much better simply based on wheelbase and stability.
  #9 (permalink)
Old 11-01-2009, 08:23 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE.
Beautiful rig sir! Nice to see they can work and play.
Tim
__________________
SCPO United States Coast Guard Retired
'04 Expedition XLT 4x2
'99 Taurus Wagon SE 24V
'88 F-150 4x4 XLT Lariat 5.8L 5Spd
Rights of Passage: CPO Initiation, Submarine Qualified (SS), Golden Shellback, Blue Nose, Order of the Ditch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
