Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 and Newer F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
The 2009 and Newer F150 Discuss the new 2009, 2010 Ford F150 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 02:31 PM
arno arno is offline
arno is starting off with a positive reputation.
Brake Controller Wiring Access??
I have an 09 with flow through console, does anyone have a trick or two to access the factory brake controller plug, behind the delete bin. The Ford directions have me removing the entire console and associated trim pieces. Seems a bit extreme, gotts be another way? Ideas?
  #2 (permalink)
Old 10-31-2009, 09:28 PM
ohboy44 ohboy44 is offline
ohboy44 is starting off with a positive reputation.
I would remove the cluster bezel and see if you can't just pull the trim piece off. The coin holder is held in with 2 7mm screws and the trailer brake controller plug is clipped into the back of it.
Even though the service manual shows a screw at the bottom of that trim piece that is behind the console I don't ever remember seeing that screw.
  #3 (permalink)
Old 11-01-2009, 07:16 PM
Quite the job, had to remove the console and most of the trim pieces have a screw or two in them. Factory directions were ok, got me through the job. All that to unclip the plug? Dont know whos bright idea that was!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
