Quote:
Originally Posted by Boss300
It all started when i changed the original clutch out and had a bad chatter after that... it has even done it while rolling forward when the engine is not running and I let the clutch out to stop the truck...
You've replaced all those parts (sometimes multiple times) yet the problem
persists, even when the engine isn't running? Is this a 4WD by chance?
The first thing to come to my mind is U-joints, then would come alignment of the
other drivetrain components. It seems to me the problem isn't in the clutch, it just
manifests itself there....
EDIT:
The Ford factory shop manual lists for possible causes:
- Engine roughness
- Throttle linkage improperly adjusted
- Equalizer bar misalignment and/or excessive end play or wrong parts installed
- Engine misaligned. Not properly seated on mounts
- Body mounts improperly torqued
- Oil or grease on clutch disc
- Glazed flywheel surface
- Clutch disc warped or bent (little or no reserve)
- Pressure plate attaching bolts loose or missing
- Loose engine mount attaching bolts
- Loose transmission and/or clutch housing attaching bolts
- Clutch housing loose or misaligned
- Pressure plate fingers bent, out-of-plane or sticking (will not return hung-up)
- Improper clutch adjustment
- Release lever (fork) bent, broken or cracked
