Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 and Newer F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
The 2009 and Newer F150 Discuss the new 2009, 2010 Ford F150 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 01:06 PM
spinrbait spinrbait is offline
spinrbait is starting off with a positive reputation.
does anyone know about the hydrolic bed steps?...
i just bought a 2009 regular cab, flareside. i wanted to put one of the hydrolic bed steps on there, after i bought it. the dealership said the steps would not fit the flareside, only the styleside. i just don't believe it. they never even looked at my truck. the step isn't bolted to the sheet metal, its bolted to frames and/bars and things. i just wanted to know if anyone has any ideas about that. i really want one bad.
spinrbait
  #2 (permalink)
Old 10-31-2009, 01:24 PM
SteveVFX4 SteveVFX4 is offline
SteveVFX4 is starting off with a positive reputation.
they only list them for the stylesides in the Ford Accessory catalog: Ford Custom Accessories Catalog
__________________
2009 F-150 Platinum 4x4 White Sand Tri-Coat
old ride: 2004 F-150 Supercrew FX4 Silver/DSG
  #3 (permalink)
Old 10-31-2009, 01:36 PM
Chris Anchor's Avatar
Chris Anchor Chris Anchor is offline
Chris Anchor is starting off with a positive reputation.
It maybe that when the step is extended, it seems to raise itself just a little and this may be the reason for them not fitting. Plus what is the distance from frame to outside edge of sheet metal, this may be it also. But I bet if you know a little about metal you could get them on your truck. There are some aftermarket steps that may fit. Chris
__________________
2009 F-150 XLT 4x4 5.4 Regular Cab 8' box 3.73 rear/max tow/8200 lbs/built in controller-One towing/ hauling machine
1996 Mercedes E300 Diesel Sedan & 1984 Mercedes 300GD "G" Wagon 4x4
  #4 (permalink)
Old 10-31-2009, 04:24 PM
Quote:
i think the ford place is going by that. but i think ford judt assumes if you have a step built in, you wouldn't need the step. but the trucks are so high, especially the 4x4, that i need a stool to get on the flare step. i just wanted the ford place to tell me why the step won't fit. what is different about the flare than the styleside. i am 99% positive it is not the different shape of the sheet metal. they look the same until you get to the flare step. i just don't think they are interested into finding out. and i don't think there is a difference, unless someone knows why. i just want one bad, and would like to know why. there is an aftermarket step, but it is nothing near as nice as the one ford has. the ford one is wider and safer too.
spinrbait
  #5 (permalink)
Old 10-31-2009, 11:38 PM
Hybris's Avatar
Hybris Hybris is online now
Hybris is starting off with a positive reputation.
Personally if you have the cash to do this then get a little in their face and ask if they can even mock one up just to see if its a possibility and if so you will gladly pay to have it installed.
__________________
1999 F-150 XL 5.4, Auto, 4x4, 8ft bed, ~160000 miles Mods K&N high flow filter 2" suspension lift
  #6 (permalink)
Old 11-01-2009, 06:05 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE.
I would imagine that the frames are already pre-drilled for any and all accessories that are applicable for a particular wheel base and chassis. Therefore, if it requires some actual work and fore thought, the dealer isn't going to do it.
I'd also be willing to bet that once installed, it wou't look right on your rig.
Tim
__________________
SCPO United States Coast Guard Retired
'04 Expedition XLT 4x2
'99 Taurus Wagon SE 24V
'88 F-150 4x4 XLT Lariat 5.8L 5Spd
Rights of Passage: CPO Initiation, Submarine Qualified (SS), Golden Shellback, Blue Nose, Order of the Ditch
  #7 (permalink)
Old 11-01-2009, 09:44 AM
johnwill johnwill is offline
johnwill is starting off with a positive reputation.
Good point. I bought and installed one of these after the fact. All holes there already on frame, and if they were not, it could not be done without major metal work.
Also, these cannot go on a 5.5 bed truck, no matter the bed style, not enough room forward of rear wheel.
Thanks
  #8 (permalink)
Old 11-01-2009, 10:18 AM
hey I was just thinking, you already have some side steps built into the flareside bed! LOL So why even need the other step right below it?
__________________
  #9 (permalink)
Old 11-01-2009, 10:39 AM
((((hey I was just thinking, you already have some side steps built into the flareside bed! LOL So why even need the other step right below it?)))))
steve, i have yet to meet anyone who can lift his foot up high enough to put it on the step. and 2 of them were over 6 feet tall. you are showing a 2004. i had a 98. the trucks are much lower to the ground than the new ones. and for a poster above, mine is a 6.5 foot bed.
spinrbait
  #10 (permalink)
Old 11-01-2009, 11:41 AM
[quote=johnwill;8095421]Good point. I bought and installed one of these after the fact. All holes there already on frame, and if they were not, it could not be done without major metal work.
well when you said the holes were already on the frame, i decided to go down to the ford dealer and check the frame of some trucks. i am now convinced that the steps will not fit on my truck. the holes are in the frame for the 2 places the step frame itself is bolted onto the truck frame. but the part of my frame, where the verticle brace bar is bolted to the frame, does not have the holes pre-drilled. i also looked at a regular cab style side, and the holes are predrilled for the verticle brace on it. so case closed, i guess.
spinrbait
Tags
box , f150 , step
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
