Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 09:34 AM
dgw57 dgw57 is offline
dgw57 is starting off with a positive reputation.
EGR Flow
Hey Guys,
My check engine light came on a while back, the code tuned out to be egr flow insuffient. I replaced the DPFE sensor and unhooked the battery cable. Light came back on after about 30 miles. I replace the EGR Valve and removed the tube that goes from the egr valve to the exhaust and made sure it was clean, unhooked the battery cable again and 30 miles later check engine light is back on and the code still shows EGR Flow Insuffient. NOW WHAT????
  #2 (permalink)
Old 10-31-2009, 10:16 AM
chaser1602 chaser1602 is offline
chaser1602 is starting off with a positive reputation.
Use the search .PLENTY of info on this
Scroll down and you can find a thread on this
  #3 (permalink)
Old 10-31-2009, 02:03 PM
Thanks found a lots of info, I beleive it is going to be clogs in the throttle body. Hope anyway.
  #4 (permalink)
Old 10-31-2009, 05:32 PM
Most likely.Very common
  #5 (permalink)
Old 11-02-2009, 02:59 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 is starting off with a positive reputation.
Lesson to learn!
You 'invested' in two parts you may not have needed.
Finding out how the system works then doing some testing would have saved you money and found the issue.
401 code failure is the result of a routine test set up by the computer to test EGR flow.
The DPFE is the test sensor that reports the results.
You have the DPFE, vacuum gate, EGR valve, test tube, hoses, electrical circuit, and blockage, all as possible faults.
Good luck.
  #6 (permalink)
Old 11-02-2009, 01:08 PM
Thudpucker's Avatar
Thudpucker Thudpucker is offline
Thudpucker is gaining momentum as a positive member of FTE.
I had cleaned all my EGR stuff and the problem came back.
Another code was Spark plugs not firing.
After a month of substituting it turned out to be the Spark plug wire ends.
I replaced those ends, had the codes reset and its been two days and no codes so far.
__________________
97 F-150/4X4/ex cab/4.6V-8/auto/Lariat,F/Glass canopy and a 77 F-150/460/C-6/ex-cab/Fglass Canopy.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
