2009 F250 Lariat Crew Cab Dash Removal - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-31-2009, 08:48 AM
mtnbike101 mtnbike101 is offline
mtnbike101 is starting off with a positive reputation.
Hello everyone,
Could someone tell me the procedure to remove the dash, switches, etc. in order to get to the radio wiring harness? My 2004 F150 SCrew was a breeze, but this is a different beast.
Thanks for any insight!
Jeff
Old 10-31-2009, 10:30 AM
LMS Residential's Avatar
LMS Residential LMS Residential is offline
LMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputation
Hey Jeff, its actually pretty easy but it would be easdier if you could see thru the dash plate/trim.
First, carefully unclip and remove the power outlet panel (lighter) on the lower drivers side of the central dash pod. Pry easily, it will come out. Directly opposite on the passenger side is a blank(in my XL anyway) identical panel, pry that out too.
That should have exposed (1) 9/32" screw on each side. Remove those. Thats it on fasteners.
The entire center dash cover can then be pried out as its installed with press in clips all the way up. I started at the bottom and carefully pulled forward until it was free, didnt break any clips. The factory radio is held in place with (4) 9/32" screws and you will need to remove that to expose the wiring harness as its on the backside and difficult or impossible to access with the radio in place. Be careful as the factory doesn't give a whole lot of extra wire at the controls, just enough to wiggle things around and out of the way. Hope this helps.
Old 11-01-2009, 10:49 AM
Thanks Ed! I'll give that a try. It's been raining for two days here, so I haven't been able to start any outside projects.
Thanks again!
Old 05-09-2013, 07:59 PM
phudyma phudyma is offline
phudyma is starting off with a positive reputation.
What about the nut on the back of the radio?... i have the panel off, the bolts out that hold the head unit in, but there is definitely something holding the radio in.... i managed to snake my dinner plate sized hand in behind ( with only a small loss of skin on my knuckles ) and could feel what seems like an acorn nut on the back of the radio.... any ideas on this would really help... I have an 09 SD and a cd is stuck in the player.... I'd like to get the head unit out to see what i can do about fixing this.....
Old 05-09-2013, 08:37 PM
Are you sure its a factory head unit? On my 08, there was nothing on the backside holding the radio in place. Been a few years but I would have remembered that.
Old 05-09-2013, 08:40 PM
Oops, it may be the antenna cable. Just grab it by the connector portion and give it a tug. Shouldn't keep the head unit from moving at all though.
Old 05-10-2013, 09:01 AM
mudfuel06's Avatar
mudfuel06 mudfuel06 is offline
mudfuel06 is starting off with a positive reputation.
There is an acorn nut or something similar on the back of the radio, I think it's used to help position the radio in there. I need to get my dash off as well to try and replace the blend door since my truck likes to give me heat in the summer and a/c in the winter.
Old 05-10-2013, 07:54 PM
yeah, there is definitely some sort of fastener holding the head unit in.... so far everything i've read is just remove the 4 bolts that hold the radio in and it pulls out.... not so, here... any ideas?
Old 07-30-2014, 09:34 PM
crp1911 crp1911 is offline
crp1911 is starting off with a positive reputation.
Quote:
Did you ever get a solution to this fastener on the back of the radio?
Old 08-03-2014, 10:05 PM
never did figure out the issue with removing this head unit..... i have a ton of music on my phone that i just link into with Sync if i feel i need something other than local radio.... but if anyone does have an answer...... please post.
1950 F3 - reduce rear springs recommend Jeff in Burlington 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-20-2016 07:35 PM
'64 F100 CrewCab Restore Jeff64F100CrewCab 1961 - 1966 F-100 & Larger F-Series Trucks 1 04-02-2015 09:14 AM
292 Generator and Voltage Regulator Jeff64F100CrewCab 1961 - 1966 F-100 & Larger F-Series Trucks 4 03-24-2015 10:52 PM
Transmission Id? JefflovesF250s Clutch, Transmission, Differential, Axle & Transfer Case 5 09-30-2014 08:18 AM
Transmission Id? JefflovesF250s 1961 - 1966 F-100 & Larger F-Series Trucks 2 09-28-2014 09:02 PM
Tags
08, 09, 2005, 2009, dash, duty, f150, f250, f350, ford, lariat, lariot, radio, removal, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
