Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 08:46 AM
mrad mrad is offline
mrad is starting off with a positive reputation.
Does tranny filter need to be changed with tranny Flush?
Here's the reason why I am asking.
A friend of mine works for a big construction company. In the winter they have him working in the shop doing routine maintenance to the equipment. His company has a machine that flushes the tranny fluid. He told me he could take my X in to work this week and flush the fluid. I asked him if he would be able to change the filter also. He told me his boss told him there is no need to change the filter on a flush, that the flush cleans the filter/screen. I told him I had not heard that before. What do you guys think?
Also how many quarts of fluid does the V10 take?
What synthetic are most of you running? I was planning on mobile 1, but thought I read in a thread that it did not meet Ford specs.
__________________
2003 XLT 4x4, V10 4.30
front and rear factory sway bar
  #2 (permalink)
Old 10-31-2009, 09:33 AM
texans's Avatar
texans texans is online now
texans is gaining momentum as a positive member of FTE.
I have never done a flush with out hanging the filter. Every shop I ever worked at changed the filter.
__________________
2006 F-250 Lariat C.C, 18" rockstars w/285/65 nittos, SCT w/custom tunes, Banks Ram-Air Intake, 5" MRBP exhaust w/o kitty, 2.5" levealing kit, readylift air bags, fumoto drain valve, Viper alarm with remote start, 2-10" MTX Subs, drilled and sloted front rotors, ARP studs sitting in shop waiting on other parts.
come Join the Texas Chapter!!
Scotty
  #3 (permalink)
Old 10-31-2009, 09:58 AM
tdappleman tdappleman is offline
tdappleman is gaining momentum as a positive member of FTE.
You should change the filter - I don't think the filter is going to clear itself unless the fluid is pumped backwards... then where does any debris go? It's a fairly cheap part and only takes a few minutes to drain the pain, remove and replace the filter.
__________________
2003 Excursion EB 4x4 V10, MT ATZ 285/75-16, Hawk LTS pads front & rear with new rotors
2000 Explorer XLT 4x4 - 30k miles
1974 Bronco 4x4 - 302, 3spd, 3.54 LSD front and rear - Restored beach toy
www.coastalfastlube.com
  #4 (permalink)
Old 10-31-2009, 10:54 AM
dvldog458's Avatar
dvldog458 dvldog458 is offline
dvldog458 is starting off with a positive reputation.
Change the filter.
Why take a chance.
__________________
2004 Excursion Limited 4x4 w/ 6.0L SCT X3 (Elite Diesel) ARP head studs, EGR Delete kit
8" BDS w/ 37" Nitto Mud Grapplers, MBRP 409 Turbo back
NJ Chapter
SEMPER FI
  #5 (permalink)
Old 10-31-2009, 02:27 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Former Ford AutoTrans Eng
Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold
A flush can't clean the filter. On the other hand, if there is enough junk in the filter that it needs to be changed the transmission is already junk.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #6 (permalink)
Old 11-02-2009, 10:04 PM
RobertH RobertH is offline
RobertH is starting off with a positive reputation.
The filter is a fiberous type material. Flushing can not remove the contamination. By not changing the filter, you risk lower flows and future damage. My first few filter changes were showing dirty colored filters, and each change the filter was less dirty once I switched over to Mercon V fluid. Last change the filter still looked new.
Not worth the damage risk for the low cost of filter replacement and it is easy on the 4R100!
Just drain the pan in a bucket. Measure the fluid drained for how much to replace. I think it was like 6 or 7 qts. Remove the bolts, drop the pan and wipe down the reusable gasket, clean out pan, pull down filter and install new filter. Lube the new seal with fluid before insertion and re-install the pan and use a torque wrench to specs so you don't damage the pan flange and gasket!
It is easier than you think!
__________________
2002 V10 4X4 Excursion
  #7 (permalink)
Old 11-03-2009, 12:20 AM
BigRy BigRy is online now
BigRy is starting off with a positive reputation.
I have seen machines that do NOT require a filter change, something about a reverse heated flow pushing contaminants from the filter and than operates with a vacuum.
But being if we were talking about my baby, I would do the filter change and new fluid.
__________________
________
Ryan
05 Limited 6.0 Excursion
Don't you just love the smell of diesel in the morning......
  #8 (permalink)
Old 11-03-2009, 11:42 AM
You can't reverse flush a transmission. The pump acts as a check valve. The only way you would be able to do that is to run the engine backwards.
__________________
Mark
  #9 (permalink)
Old 11-04-2009, 12:36 PM
It looks like it will not work to have my buddy do the flush. I called a local garage and they will pump my fluid through for $50. They also told me they offer a flush kit that provides an additive that conditions the seals for an extra $32. Anyone know anything about this additive and if it is worth the $32.
My vehicle has 78,000 miles on it. I bought in March. I do not know if the fluid has been changed before.
Thanks
__________________
  #10 (permalink)
Old 11-04-2009, 05:13 PM
aklim's Avatar
aklim aklim is offline
aklim has a good reputation on FTE. aklim has a good reputation on FTE.
Thanks
I have heard of those additives. I generally put additives into the "Snake Oil" bin unless they can prove that it works. Have you seen any proof by an independent lab with certified scientific methods?
__________________
01 Excursion. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, Van Turbo and BDP Stage II AC injectors. Bilstein Shocks with U code front and A code Rear. 203* thermostat and billet housing
  #11 (permalink)
Old 11-05-2009, 04:54 PM
VR6Nutt's Avatar
VR6Nutt VR6Nutt is offline
VR6Nutt is starting off with a positive reputation.
Just did mine last weekend myself (again - thanks to FTE!) Replaced filter and used the rear cooling line method for complete flush. Used this fluid: Lubrication Engineers - 1150 TRANS-ALL EHP Automatic Transmission Fluid Works great again!
Just curios - u are referring to the pan filter, right? Not the in-line one installed by Ford when they replace trannies...?
__________________
2003 Excursion 7.3 PSD
AFE Stage2 • JW 4R100 • 6.0 cooler • CCV • AIH Delete • ITP OBA • DP-Tuned • RAS • 285/75 Nitto Terragrapplers LR E • AFE 4" Exhaust • Gauges
  #12 (permalink)
Old 11-06-2009, 12:02 PM
MagKarl MagKarl is offline
MagKarl is starting off with a positive reputation.
I've had the same experience as RobertH. We bought our Ex with 28K on the clock. The first time I changed the fluid it looked and smelled fine, but there was a fair amount of fine debris on the pan magnet and in the filter. Then next time I did it, maybe 30K later, there was much less debris. I always change my trans and oil filters when I change the fluid, the cost is minimal for my peace of mind.
__________________
1995 F350 XLT CC 4WD PSD 5 Speed
2001 Excursion Limited 4x4 V-10
  #13 (permalink)
Old 11-08-2009, 09:50 PM
Seems the Mercon V definately is an improvement. By the filter being so clean the last time, it was bright pink and not grey so that means it is still very clean. The new Filter material is white, so with the fluid it takes on the color of the pink fluid. I think initially, within the first 30K, the breakin particles are collected in the filter and magnet. However, the second change can't get all the debris, so the second change gets the rest. Evidenced by the 3rd change where the pan, magnet and filter were all clean. I really believe the Mercon V is an improvement and understand it is semi synthetic. It seems to shift smoother also. Have heard others that switched realize smoother shifting and overall improvement.
Have another 25K to go before the next change. I expect it will be clean again. Simple change process including the filter so not any excuse to overlook this very important step! Clean filter means improved fluid flow and longer life!
__________________
  #14 (permalink)
Old 11-08-2009, 11:00 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
That filter is supposed to be doing life in the confines of the pan.....About 17 quarts total.......don't go for the snake oil additive, that stuff has been around since the 49 olds Hydramatic. It's just a solvent that will soften your seals over a period of time. It could be hazardous to it's health but OK in in pinch if it is on the way out. You can buy the same snake oil at the auto store for $3 and dump it in............ripoff!
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
Tags
2004 , 2006 , automatic , change , changing , clean , f150 , f250 , filter , flush , flushing , ford , tranny , transmision , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordฎ is a registered trademark of the Ford Motor Company.
