Play in drive shaft - Ford Truck Enthusiasts Forums
Play in drive shaft
Old 10-31-2009, 07:55 AM
ltl_jrw's Avatar
ltl_jrw ltl_jrw is offline
ltl_jrw is starting off with a positive reputation.
Play in drive shaft
Not a lot but I can turn (rotate) my drive shaft some, my transmission is in park. Is there anyway to tighten the rear yoke to take up the slack? Also should there be any slack in the transfer case. My truck is a 99 F350 dually 4:10, what rear end is under my truck, a Dana or what?
Old 10-31-2009, 08:15 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
How much can you turn it? Theres always a little slop.
Old 10-31-2009, 08:16 AM
mxracer3276's Avatar
mxracer3276 mxracer3276 is offline
mxracer3276 has a very good reputation on FTE.mxracer3276 has a very good reputation on FTE.mxracer3276 has a very good reputation on FTE.
Quote:
Most dually's are equipted with Dana 80's in the rears. As for the play, i am not sure, might be a symptom of the carrier bearing going out, not sure though, more will chime in.
Old 10-31-2009, 09:48 AM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
The duallys' have a Sterling
Old 10-31-2009, 10:43 AM
ltl_jrw's Avatar
Thanks to all. How would I know if it's a Sterling or a Dana 80 ? As for how much slop, I can turn it about an an about a 1/4 inch.
Old 10-31-2009, 11:45 AM
Is it kind of like this?
If so, no worries.
P1040615.MOV videos from trucks videos on webshots
Old 10-31-2009, 12:05 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Dan,
Nice videos for the in-experienced, like me, to use for comparison.
Reps to you.
Old 10-31-2009, 05:14 PM
ltl_jrw's Avatar
Quote:
If so, no worries.
Yep thats what I have, no more than that
Old 10-31-2009, 06:24 PM
Quote:
Originally Posted by PaysonPSD View Post
Dan,
Reps to you.
Thank you.
That's just the parking gear. Drive it and enjoy.
Old 10-31-2009, 07:29 PM
ltl_jrw's Avatar
Thank you.
One more question, I understand the parking gear having that much slop BUT should there be that much with the truck on the ground, I bet that video was when the truck was on a lift.
Old 11-17-2009, 06:25 PM
ltl_jrw's Avatar
With all the tires on the ground should there be any slop in the drive shaft? And if not how do you get slop out of the rearend?
Old 11-17-2009, 07:09 PM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to behold
You will still have slop with the wheels on the ground.
Old 11-18-2009, 06:13 AM
ltl_jrw's Avatar
Quote:
Thanks, I just thought that the pinion should not have any slop. I don't like that and thought there was wear in the ring and pinion.
Old 11-18-2009, 08:18 AM
You need a little bit of play to allow the gear oil to get in between the teeth.
Also there will be more slop on the spiders than the ring and pinion.
You may be feeling that slop vs the bit of space allowed for the ring and pinion.
O1 Excursion RWD slack in driveline fast_lap Excursion - King of SUVs 4 10-08-2016 08:04 PM
2000 F250 4x4 - Drive Line Noises cuazman Clutch, Transmission, Differential, Axle & Transfer Case 2 05-21-2016 07:29 PM
2012 F250 Drivetrain Noise F350Man79 1999 to 2016 Super Duty 1 12-30-2015 09:53 PM
my rearend hurts martenlunsford Bronco II 1 07-09-2004 02:40 PM
slack in rear lal357 Clutch, Transmission, Differential, Axle & Transfer Case 1 07-03-2003 04:57 PM
Tags
1999, carrier, case, drive, driveshaft, f150, ford, play, rear, shaft, transfer, transmission, turning, wheels, yoke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
