Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 03:18 AM
dadstan76 dadstan76 is offline
dadstan76 is starting off with a positive reputation.
does my truck already have a ballast resistor
I just ordered a Painless Duraspark wire harness and it comes with a ballast resistor. I was wondering if my truck already had one. It is a 1976 F150 4x4. It had a 360 but I put in a 390 a couple weeks ago. Here's the harness: Painless Wiring 30812 - Painless Performance Duraspark II Distributor Wiring Harnesses - Overview - SummitRacing.com
Thanks all
__________________
If it ain't red, leave it in the shed
  #2 (permalink)
Old 10-31-2009, 02:02 PM
fmc400's Avatar
fmc400 fmc400 is offline
fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE.
If your truck's wiring is original and has never been modified, it will have the ballast resistor. It's a special length of resistance wire that is integrated into the harness itself. If you crawl under the dash and look at the wire pigtail coming from the back of the ignition switch, you can see where it starts. It's a red/pink color, and has "DO NOT SPLICE" or "DO NOT CUT" printed on the insulation.
  #3 (permalink)
Old 10-31-2009, 05:47 PM
Thanks Do you know if I should install the resistor that comes with the harness even if I already have the wire? Would it do any harm to have two?
__________________
  #4 (permalink)
Old 10-31-2009, 05:52 PM
ctubutis's Avatar
ctubutis ctubutis is online now
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
Quote:
I wouldn't install two, the factory resistor/resistance wire should lower the
voltage to factory specs, adding a second could cause problems.
  #5 (permalink)
Old 10-31-2009, 06:01 PM
Good, the aftermarket resistor looks like crap anyways.
__________________
  #6 (permalink)
Old 10-31-2009, 10:12 PM
JimsRebel's Avatar
JimsRebel JimsRebel is online now
JimsRebel is starting off with a positive reputation.
Check the voltage at the coil + at idle, it should be 6-8 volts or so.
Are you using s DS2 IGN system?
__________________
1986 F150 XLT Lariat 4x4 300 C6, 9 inch 3:50, sway bars, DS2 w/ GM 4 pin and no computer; 90,000 miles, 2nd owner
  #7 (permalink)
Old 11-01-2009, 01:45 AM
Yes, I am replacing the whole harness because someone cut the heck out of the old one. It's probably the original point harness with wires added for the DS II. For example, someone cut off the connectors and wired the harness directly to the distributor.
__________________
  #8 (permalink)
Old 11-01-2009, 11:00 AM
JimsRebel's Avatar
Most of the DS2 harness I see at the junk yard have been cut up, if I find a good one I grab it and put it on ebay (item 220479939960). They dont seem to be in high demand anymore so I dont really even look for them now, use to get $30-$40 each but now just usually one bid.
I think a lot of people are using the HEI one wire coil in cap style Dist now.
__________________
Tags
1976 , ballast , ford , location , resistor , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
