Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-31-2009, 12:08 AM
Lignite Lignite is offline
Lignite is starting off with a positive reputation.
Air/fuel ratio won't richen under boost
I have a '97 5.0 out of an explorer (gt40p I believe) in my Ranger, with a small remote turbo @ 5psi, 255lph walbro hi-pressure, 39# injectors, AEM air fuel gauge (wideband), 90mm lightning MAF. PCM tuned by Sniper Special Forces (which I no longer have acces to).
A/F ratio was tuned to richen down to 11.7 (actual 11.6-11.9 on a/f gauge) when you get heavy into boost. All of the sudden it no longer does that and remains the constant 14.7 (14.6-15.1) even into boost which is dangerous as I understand it. What could cause this? I'm told the PCM can't 'lose its tune' (but it sure seems like it), so what mechanical mechanism can be fooling the computer into not richening the mixture?
It also has a miss (stutter) while at cruise speed (about 2000rpm/65mph on the highway). So far I've changed out a fuel pump, new plugs, fixed a broken EGR rubber hose (blowtorched my heater box). Have a new plug wires and DPFE on the way. Idles great, runs great under any kind of minor (or even major) acceleration.
I'm at a complete loss, and I'm skeptical my local (and only near) dealer will be able to get a grip on this custom application. Any advice would be greatly appreciated.
  #2 (permalink)
Old 10-31-2009, 10:46 AM
Lead Head Lead Head is online now
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
If you have access to a scan tool that has a live data feed mode, make sure you when you put the pedal to the floor, the throttle position sensor reads 100%. If the throttle position sensor will not read 100% throttle, or close to it when wide open, then the computer will never go open loop and use the richer mixture.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #3 (permalink)
Old 10-31-2009, 10:47 AM
Conanski's Avatar
Conanski Conanski is online now
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Is this setup using a MAP sensor to measure boost? If so is this device operational and is the vacuum line attached and intact? Are there any codes in the computer?
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #4 (permalink)
Old 10-31-2009, 03:37 PM
No related codes so far, but I will be checking again sometime next week, as well as a fuel pressure check hopefully. Boost/vacuum gauge is working properly I believe, but I'm not sure where it measures at; I don't beleive it uses a MAP sensor, the MAF takes the place of that I believe? The Maf appears to be clean and operational, though I don't know how to test voltages to know for sure.
  #5 (permalink)
Old 10-31-2009, 06:26 PM
Conanski's Avatar
1990 Ford F-150
Yeah if you don't have an FMU in the fuel system then fuel enrichment is strictly under computer control.. which means the tuner is no longer doing it's job.
__________________
Paul O
  #6 (permalink)
Old 11-03-2009, 11:33 AM
I apologize as I don't think I'm stating things correctly for you to understand. The Explorer PCM (computer) was reflashed with a new tune, the PCM knows (or knew) to enrich the mixture when it was supposed to. I'm told this is stored in permenant Read Only Memory and can't be lost (even though it seems like it has). Therefor there must be a sensor somewhere that is not sending incorrect information to allow the PCM (with its new parameters) to run things correctly. Or is the PCM itself bad?
I keep thinking something in the EGR system, as the ruined hose to the DPFE occured generally at the same time as the miss at ~2000rpm, and the problem with a/f ratio. Maybe its coincidence though, and something else is up? New plug wires and DPFE going in soon. After that I guess its on to coils and throttle position sensor? I'm really needing a good scanner for this rig, Christmas may have to come early this year. Thanks for the help so far gents, all help is greatly appreciated.
  #7 (permalink)
Old 11-03-2009, 02:38 PM
If you have a buddy with another 5.0 EFI, I'd try seeing if you can convince him to let you borrow his TPS and see if it makes a change. A computer will not just loose its programming.
__________________
- Ian
  #8 (permalink)
Old 11-04-2009, 01:50 PM
Conanski's Avatar
1990 Ford F-150
I understand what you're saying.. my comment about the FMU refers to another type of boost compensation that you are obviously not using. If the PCM can be reflashed it can also lose the new calibration..though this should not just happen for no reason. A problem with the TPS or MAF meter could cause this type problem but that should also throw a code, so maybe your computer did lose it's programming. A scanner will tell the story.
__________________
Paul O
Tags
af , afr , air , boost , change , f150 , fixed , fuel , part , position , programming , ratio , scanner , sensor , throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
