Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-30-2009, 11:50 PM
bill11012's Avatar
bill11012 bill11012 is offline
bill11012 is gaining momentum as a positive member of FTE. bill11012 is gaining momentum as a positive member of FTE.
OBS 7.3 and SD 7.3, what is the difference?
I see they have different threads, but what did ford change?
__________________
my V10 will out pull your PSD any day of the week.
Quote:
Originally Posted by Jmeyer1990
... but i kept losing service in Victoria's Sectret, so I gave up.
Originally Posted by bghnkinf250
Can I retrofit a catalytic converter to my butt?
  #2 (permalink)
Old 10-31-2009, 01:01 AM
rollerstud98 rollerstud98 is offline
rollerstud98 is starting off with a positive reputation.
I don't think they were intercooled in the obs were they? also completely different truck for one. different injectors, turbos likely, i don't know what else since i'm a 6.0 guy
  #3 (permalink)
Old 10-31-2009, 01:11 AM
bill11012's Avatar
I know the truck is different, I meant the motor its self.
I think you are right about the intercooler.
__________________
  #4 (permalink)
Old 11-02-2009, 09:43 PM
parkland's Avatar
parkland parkland is offline
parkland is gaining momentum as a positive member of FTE. parkland is gaining momentum as a positive member of FTE.
They are totally different. Nothing is interchangeable.
The OBS used 7.3 Indirect mechanical injected non-turbo engines.
The new are direct injected electronic hydraulic injected turbocharged engines.
The stroke & bore are identical I believe, but everything else is upgraded to handle more power and more advanced systems.
It's like comparing the newer 7.3's with the 6.4.
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #5 (permalink)
Old 11-03-2009, 01:21 AM
95_Dually's Avatar
95_Dually 95_Dually is online now
1995 Ford F-350
95_Dually is gaining momentum as a positive member of FTE.
The 94.5 - 97 OBS PSD's are Direct Injection and have Turbos. The motors are very similar between 94.5 to 2003. Parts can be interchanged as long as specific parts are used as well. IE: the turbos can be interchanged as long as you use the pedestal and the spider intake.
__________________
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <><
95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD
2000 Ranger 4X4 No MODS, yet!
  #6 (permalink)
Old 11-04-2009, 06:16 PM
bill11012's Avatar
I think you are thinking of the 83-94 IDI 6.9/7.3.
All the 95-03 7.3s were DI.
__________________
  #7 (permalink)
Old 11-10-2009, 04:46 AM
drivembig's Avatar
drivembig drivembig is offline
drivembig is starting off with a positive reputation.
I know that there are a lot more people to chim in on this that knows way more than I do, but the first generation (1994.5-1997) versus the second generation (1999-2003) I think are very similiar.
I know that the fuel pressures are different. The injectors are a little different, but I think can be interchanged. The HPOP (High Pressure Oil Pump) is different, but also can be interchanged. The turbo got an intercooler, which can also be put on the first generation. The waste gate on the second generation is also different. AS mentioned in a previous thread, you can put the second gen turbo onto a first gen if the pedestal and mounts are also used. I'm sure the IPR is different as the higher pressure HPOP. The IDM is of a higher voltage, which can also be used on the first gen.
Someone please chim in and take it from there. Correct me if I'm wrong or add to what I have missed.
__________________
2003 Ford F-250 5.4L Triton V-8
1995 Ford F-350 Dually 7.3L Powerstroke Turbo Diesel
1995 Chevrolet 1500 Silverado 5.7L V-8
  #8 (permalink)
Old 11-10-2009, 10:03 AM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
I don't know all the little differences- what I do know off the top of my head is that the 94-97 7.3 PSD was non intercooled, and had a non-wastegated turbo with a 1.10 AR turbine housing and a squished downpipe. '99-03 7.3 had an intercooler, the turbo was essentially the same except it had a .84 AR wastegated turbine housing and I was told it had a better compressor wheel. It also had a real downpipe.
One thing also of note was that as far as I know, the PSD in E-series vans was always non wastegated with the 1.10 housing, even when the SD trucks were wastegated.
__________________
1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs. 4" intake tube, ATS upgrade, 4" exhaust w/ Walker 21172, boost & pyro on pillar, Autodim mirror, 16x8 MB Razor wheels w/285/75R16 "MT-R's"
1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners
2008 V-Star 1100 Midnight Custom-Just Cobra slip-on drag pipes for now
Tags
1995 , 1999 , 73 , custom , difference , f350 , ford , gen , interchangeable , obs , parts , pedestal , truck , turbo , upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
