I have an 2008 f-250 2wd and would like to replace the steering stabilizer with something a little heavier, but can't seem to find one available, does anyone know if they make one? Thanks.
__________________
2008 ford f-250 cc 5.4 super duty , raider hi rise camper top with thule ladder racks, front winch bumper top gun, rear bumper top gun,12,000 lb. winch, 98 gal. aux tank, on board 12 volt puma air compressor w/10gal tank and 50' auto hose reel,1000 amp 2nd battery,1,000,2,500,6,000 watt power inverters, 9" hid lights, running boards, air horns by hadley, xm radio, fac. 6 cd nav. center, air bags, cb,2-4'12volt flourescent lights in back.
Can that be done with a two wheel drive? That is my problem, I can't find one for a two wheel drive.
__________________
man that's the second time in two days i haven't seen 2wd in a post and said something stupid, i gotta lay off the miller lite before posting apparently. no idea about your setup, sorry
__________________
Bryan
2007 F-250 6.0L PSD FX4
Growing four inches straight up by Christmas
I have my Return Authorization # right in front of me as I ordered that steering damper and it isn't even close. Told the rep from CPH that it does not work on 2wd and he said they would look into it, apparently hasn't been changed yet. The damper they sent has 1 threaded end and 1 sleeve and, if you look up under your truck, you'll see that you need a damper with a sleeve/bushing at both ends. I'm staying posted as I'd really like to change mine and have been told the Motorcrap OEM is no good.
Hey John, the timing on that was dead on. Dropping the package at FEDEX on my way out. I'll add that the customer service at CPH was excellent, RA was in my email the following morning.
That's great to hear....good customer service is huge. Not to hijack but I just got my Bilsteins mounted yesterday. Shock Warehouse. I ordered them with free shipping on Monday and fully expected them to not be here until next week sometime (free shipping generally means SLOW). Got them Wednesday and they're on now. I WILL use Shock Warehouse again.
__________________ John
2005 F-250 SD Lariat CC 4x4 6.0 TS Auto.
2007 GMC Yukon Denali
Glad you caught that, I looked those up and there others they say will fit that app. on that web site, did you see the skyjkr part# s977500, mfr. #7500 they say it will fit 2 or 4wd, open it is 17.06 in., closed 10.48 in., is that the one you had? Thanks, let me know if you find one, I'll keep looking.
__________________
Hi Bayou, yep that's the one I got. The box said (took notes in case of a prob with return) "Skyjacker hydro7000 steering stabilizers" and the side panel stated Skyjacker OEM stabilizer SKY7500, but under that sticker was the #7003, which, to me, sounds like it might just be a different Skyjacker part #????? in which case the fault may well have been exclusively at CarPartsWholesale. I'm going to see if I can contact Skyjacker direct as, again, I really want to correctly replace mine. I'll post what I find out.
__________________
