Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-30-2009, 07:19 PM
KevinC.'s Avatar
KevinC. KevinC. is offline
KevinC. is gaining momentum as a positive member of FTE.
Click click...
Starting this month, my truck doesnt turn over every now and then. When you turn the key you just get a click from under the hood. If you cycle the key quickly a few times she would eventually turn over and start, but today I can not get it to turn over. I just replaced the solenoid under the hood with no luck. Also, the batteries are strong, and the starter is only 5 months old.
Does anyone know what this could be??
__________________
95 F250 XLT, 7.3 PSD, 5 Speed, Reg Cab, 2WD, 180cc Stage 1's, PHP, 3" DP to 4" straight pipe, Electric fuel pump w/ twin WIX filters, Autometer: Pyro, 6637, 140v IDM, CCV, Kitty ran away.
  #2 (permalink)
Old 10-30-2009, 08:43 PM
etldak etldak is offline
1996 Ford F-250
My Garage
etldak is starting off with a positive reputation.
sounds like a starter.
__________________
1988 F250 XLT ex-cab LB 4x4 7.3 5 speed zf. 33/12.50.16.5.true dual 2.50 exhaust. mine
1996 F250 XLT cx-cab LB 2x4 7,3 auto Derale 13700 trans cooler trans,boost pryo gauges,TCI RV Trans.3'' Down Pipe.Hers
  #3 (permalink)
Old 10-30-2009, 09:00 PM
kawa's Avatar
kawa kawa is online now
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
X2 what he said. Pull the starter and have it tested. If you have a "Shunt" style Amp gauge place it over the cable to the starter and have someone attempt to start the truck, read the amp gauge, it will probably peg the meter.
Rog
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
  #4 (permalink)
Old 10-30-2009, 09:40 PM
KevinC.'s Avatar
Glad its got a lifetime warranty. I'll let yall know if the new one helps. Thanks!
__________________
  #5 (permalink)
Old 10-30-2009, 09:44 PM
95_Dually's Avatar
95_Dually 95_Dually is offline
1995 Ford F-350
95_Dually is gaining momentum as a positive member of FTE.
X3 what kawa said. Definitley sounds like a starter!
__________________
Sam
Humble yourself and give thanks to GOD.
<>< Family of 7 saved by Grace <><
95 CC Dually 3inch downpipe no muffler/cat Edge Programmer, 6637 MOD, 140v
2000 Ranger 4X4 No MODS, yet!
  #6 (permalink)
Old 10-31-2009, 12:04 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is starting off with a positive reputation.
x4, mine did the same thing a few days ago. New one fixed it.
__________________
Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
  #7 (permalink)
Old 10-31-2009, 07:50 AM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
FTE Sponsor
DZL JIM is gaining momentum as a positive member of FTE.
Sounds like connections to me. Take off every cable and every connection and clean every surface/terminal thoroughly.
I had this happen to me at McD's once with the wife and she'll never let me forget it. Held up the whole drive-thru lane for probably 10 minutes till I could get the truck started again.
All it needed was clean contacts.
__________________
'96 F-350 Reg Cab 4x4 PSD
'97 F-350 CC Short Bed 4x4 PSD
StackCovers.com
DieselJunk.com
DZLJIM.com
  #8 (permalink)
Old 10-31-2009, 06:25 PM
triskadek's Avatar
triskadek triskadek is offline
triskadek is starting off with a positive reputation.
I had the wife-mod and the sister-in-law mod both witness mine doing the same thing for the first time today. I'm sure I won't be allowed to forget it either.
Going to check the contacts first, but if that is all the problem is, recreating the problem for verification is difficult if not impossible.
  #9 (permalink)
Old 10-31-2009, 06:35 PM
FARM69's Avatar
FARM69 FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
I agree with Jim.. Check the connections. I've had this happen to me several times.
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / HX50 Turbo (19cm) / DP-TUNER / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water/Oil Temp]
4" Straight / 6637 / CCV / 203 Stat
  #10 (permalink)
Old 11-01-2009, 12:41 AM
95_Dually's Avatar
1995 Ford F-350
When I had the CLICK CLICK problem, I had my wife turn the key while I smacked the starter with a hammer. It turned over and I knew for sure the problem was the starter.LOL
__________________
Sam
  #11 (permalink)
Old 11-01-2009, 08:24 AM
KevinC.'s Avatar
I didnt feel like pulling the starter that I had just recently installed until I tried all the other options. I put on all new battery terminals, cleaned the battery lugs to a shine, and installed a new solenoid. Still, just a click. I arced the solenoid on the fender and she started, this doesnt make sense unless the one I bought was bad right out of the box.
__________________
  #12 (permalink)
Old 11-01-2009, 11:59 AM
95_Dually's Avatar
1995 Ford F-350
That does sound like a bad solenoid. If you jumped the solenoid and the truck started then I would I would say the solenoid is not working properly.
__________________
Sam
  #13 (permalink)
Old 11-02-2009, 02:55 PM
KevinC.'s Avatar
Wierd. It was the starter, my buddy turned the key while I tapped it with a hammer. Fired right off. I would have thought a rebuilt starter would last more than 5 months.
Thanks everyone!
__________________
  #14 (permalink)
Old 11-02-2009, 04:53 PM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg is starting off with a positive reputation.
I had a starter that only lasted a little over a month. Apparently the rubber plug fell out of the bottom. I was over my Mom's (Outer Banks) out on the beach, I thought the tide was going out but in reality the tide was coming in. I had to drive through the water (salt) to get out before the tide came all the way in. It left me at a "7-11" one morning. I had a nice passerby crank it while I smacked it with a hammer, nothen but big blue sparks! It just left me there w/no warning. This may have also contributed to my brakes problems that followed soon after. Lesson learned: salt water, stay away from it if possible.
__________________
Ian pronounced E-N just like the letters sound. 97 F350 7.3L Auto 4WD Crew Cab 195K. MODS: HOOOOGA! horn, PO MAN's air intake, Service/Utility bed, 3" DP, Testing that Cat, FPR shim (whoknows PSI), 140v IDM, 2 10K pots. US ARMY OAS, OJE-IFOR, SFOR,2,5, OJG-KFOR, OIF, OEF.
To ALL that have served, THANK YOU!
Tags
click , ford , start , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
