Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-30-2009, 06:56 PM
THAT.GUY's Avatar
THAT.GUY THAT.GUY is offline
1972 Ford F-100
THAT.GUY is starting off with a positive reputation.
72' F100sc cab removal
I was wondering how hard it is to remove the cab of my truck. I want to redo the suspension and a guy at my work says to take off the cab so we can have all the rome we need. I know I want to replace the bushings, but is it really worth it? Any advise helps thanks
Ryan
  #2 (permalink)
Old 10-30-2009, 07:46 PM
Danger_Dave's Avatar
Danger_Dave Danger_Dave is offline
Danger_Dave is gaining momentum as a positive member of FTE.
sounds excessive
__________________
1969 F100 RANGER 360 C6
  #3 (permalink)
Old 10-30-2009, 08:47 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
Pulling the cab will gain you nothing for suspension access. Pulling the nose off, maybe, but then you need to re-align it on there.
To pull the nose, just take out the three bolts on each side where the inner fender brace bolts to the firewall brace, the bolts holding the spray shields to the firewall, and the two front mount bolts. Drain the radiator and remove it, unplug the harness connectors at the firewall and from the engine, and then two guys can remove the nose easily.
__________________
Jared
The government said all my vehicle were too old to be clunkers
FTE Guidelines
  #4 (permalink)
Old 10-30-2009, 09:30 PM
first today's Avatar
first today first today is offline
first today has a good reputation on FTE. first today has a good reputation on FTE. first today has a good reputation on FTE.
It is easier to remove the front end if you also remove the front bumper.
__________________
Call me Kyle
_____________________________
  #5 (permalink)
Old 10-31-2009, 02:31 AM
DLP Performance DLP Performance is offline
DLP Performance is starting off with a positive reputation.
That's crazy! You don't need to take any body parts off for suspension work!
  #6 (permalink)
Old 10-31-2009, 03:05 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE. ford390gashog has a great reputation on FTE.
There is zero point in removing body parts. You have all the room you need under the truck and will gain zero by removing the cab! Besides the cab is not even above any parts you are going to work on.
__________________
If it doesn't fit, FORCE it.
If it breaks, well, it needed replacing anyway.
  #7 (permalink)
Old 10-31-2009, 06:12 PM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE.
Ryan, I agree with others, don't remove any sheet metal, just jack the truck up.
It's not a lot to change to begin with.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #8 (permalink)
Old 10-31-2009, 08:05 PM
THAT.GUY's Avatar
1972 Ford F-100
My truck is down to bare frame. The only thing I haven't taken off is the cab. You can see what I'm working with in my profile. See the guy at my work says that taking the cab off will make it easier for the two of us to put on my Crown Vic front end and redo the rear suspension to even the truck since the CV suspension will lower my truck 5"-6". I never done any of this before so I have no idea what to do.
  #9 (permalink)
Old 10-31-2009, 11:08 PM
19704X4F250's Avatar
19704X4F250 19704X4F250 is offline
19704X4F250 has a good reputation on FTE. 19704X4F250 has a good reputation on FTE.
Pull the cab if you are doing a frame off, that way you can clean the frame under the cab. BTW, I looked at the pics in your gallery. The doors you have are from a 1967 not a 1972. They are oddballs and year specific to 1967 as nothing from 1968-1972 will fit them (except the window glass) if you need parts.
__________________
Dan
Ignorance makes you start over!
IF IT IS MADE IN CHINA, YOU DON'T NEED IT!
Torque it down till it breaks off, then back it off 1/4 turn.
  #10 (permalink)
Old 11-01-2009, 05:59 AM
jowilker's Avatar
1966 Ford F-100
Quote:
The things that guys add when they post again.
Sorry bub there was no flashing light in your profile saying major restore project going on here. I would have given a different reply.
How long have you been on the project and when do you expect completion?
John
__________________
  #11 (permalink)
Old 11-02-2009, 12:49 PM
THAT.GUY's Avatar
1972 Ford F-100
I knew that my doors were from a different truck, b/c when I first got the truck in April of 09' I wanted to check the title to VIN tag. The VIN tag on the door came up as a 67 F350. I didn't know about the 67' doors being different. I want to make this truck just a crusier. The Mustang I had was never reliable so I want to make sure this trucks runs and looks good. I have been working on the truck since March 09' all by myself. This is all a learning experience for me. I love to work on cars and this is my chance to fix one up so I want to do it a little more than half ass. I'm young so I have plenty of time it's the money factor
  #12 (permalink)
Old 11-02-2009, 01:27 PM
Well, in that case, spend 15 minutes to take the 4 bolts out & lift it off. The "guy at your work" should've known this, since he's a master chassis expert & all.
  #13 (permalink)
Old 11-02-2009, 06:36 PM
THAT.GUY's Avatar
1972 Ford F-100
Oh come on now don't start being an ass. The guy at work and I know how to get the cab off the frame. I know where the four bolts are and we have a fork lift at work. I just read in another thread that a guy had trouble with the removal. I will take it off tommrrow night. For anyone that wants to be a smart ass what should I do just undo the bolts and pull? On the doors, is this gonna be a issue for me later?
  #14 (permalink)
Old 11-02-2009, 06:57 PM
Unfortunately, there is one in every forum. Why he is picking on you, I haven't a clue.
Don't forget the e-brake cable or the steering shaft if you haven't already done so. Then it is just the 4 bolts. If you haven't pulled the tank, you will have to, to get to the back bolts. Be prepared to do some repair work to the mounts as they liked to collect salt and rust. The doors will fit and work fine, just remember what year they are if you need to get parts. Been there, done that.
__________________
Dan
  #15 (permalink)
Old 11-03-2009, 12:40 PM
97nukeford's Avatar
97nukeford 97nukeford is online now
Nebraska Chapter LDR
2006 Ford F-250
My Garage
97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of
I'd go ahead and pull the cab. It's not a lot of work, and it's worth it to check out your cab mounts, and get a good look at your rockers and such on the bottom side. I'm doing the same with my 67.
__________________
Pat W.
Nebraska Chapter Leader and Official #2 Slackmaster!
2006 F-250/ 1997 F-150/1967 F-100
1967 F-100 Project
GO HUSKERS!!
CLICK HERE TO JOIN THE NEBRASKA CHAPTER!
Tags
19681972 , 72 , bushings , cab , cabs , fi50 , ford , information , removal , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
