Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 10-30-2009, 10:55 PM
David85's Avatar
David85 David85 is offline
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
I hear the 7.3 series powerstrokes are a decent engine but IDIs are just as reliable and have lower cost parts so they are easier to maintain in the long run. In practice, the electronics on the powerstroke are not impossible to deal with, but they can leave you stranded on the side of the road. Mechanical diesels don't have computers or sensors to go goofy.
I drove a 95 powerstroke with 5 speed once and had mixed feelings until I found the go pedal. It idled like it was about to fall apart but apparently thats how they normally sound. I'm used to the more polite, smooth idle of an IDI (ford or GM for that matter).
Up to 1000 RPM feels like crap, then right around 1500 all hell breaks loose and the turbo spools. I'll admit I was impressed and that truck could have probably outran mine at least until it ran out of RPM. It did have an upgraded downpipe so I suspect it was putting out more than the stock Hp.
The engine bay was also fairly clear. I know we like to rip on them because you have to remove the valve covers to get ot the injectors or glow plugs, but the covers are right in the open and easy to get to. The wiring integrated valve cover gasket is reusable, so as long as you don't abuse it, thats not an issue either.
One thing I don't like about the powerstroke is there is a large amount of oil in the upper end of the engine that doesn't get drained out from the injectors, HPOP, and related plumbing. There is a method to drain it out, but it gets messy and is much more trouble than a run of the mill oil change. I guess thats good news for us because it means powerstroke filters have to be that much better.
Throttle is also too sensitive for my taste. Makes it harder to get good fuel economy in normal driving.
The hydraulic injection system was a ballsy move I'll admit and while it does work, common rail is much better and should have been used from day one if ford insisted on moving away from the stanadyne DP2 injection system. I don't buy the argument that it was because of emissions because GM kept their 6.5 IDI and it did just fine under the same rules.
1 powerstroke injector = 8 IDI injectors in terms of cost.
8 powerstroke injectors = 8 IDI injectors, new custom hot pump, and plenty of cash left over to plan some other upgrade (or just save it).
8 powerstroke injectors AND HPOP = you get the idea.
I don't care how reliable the hydro injection is or if they really do last the life of the engine as many claim. That is not an investment that will pay off even if the IDI injection system really did wear out 8x faster. And we know it doesn't.
If raw horsepower is all you are after, then sure get a powerstroke and have at'er with a chip. My truck needs to pay for itself everyday and I know a computer controlled engine will never do that.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #17 (permalink)
Old 10-31-2009, 05:03 AM
tjc transport's Avatar
tjc transport tjc transport is online now
oh no, not again!!
tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation.
i have both. an idi and a stroker.
the idi will outwork the stroker any day of the week. .the stroker is my daily driver. but if i need a "road dozer" the 88 comes out of hibernation to get the job done.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of way too many fords.
  #18 (permalink)
Old 10-31-2009, 12:40 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn is starting off with a positive reputation.
Wow David, very well said and all so very true!! I did drive myself a 2001 PowerStroke and wow they got balls compared to my IDI's but, looking under the hood, and understanding how everything works under there, and cost of parts.... sure makes me love my old gutless IDI's way more
__________________
Driving a Diesel adds a whole new meaning to smoking the competitor!
1990 Ford F250 4x4 5 speed 4.10 gears N/A 7.3 Diesel 568,000km/375,000miles, still on the orignal clutch!
1987 Ford E350 C6 Trans 3.55 gears N/A 6.9 Diesel Motorhome 26ft. weighin' 11,000 pounds and it's slow goin' up hills lol.
  #19 (permalink)
Old 10-31-2009, 12:59 PM
GenLightening GenLightening is offline
GenLightening is starting off with a positive reputation.
One issue you may have (check with the TX DMV) is putting an older engine into a newer vehicle. They usually require the engine to conform to the newer emissions regs. Not sure how different the '95 would be from the '88 though. And you might be able to say it's out a '94 (wink, wink).
__________________
Doug
'88 Chevy 1Ton CC DRW 2WD w/a 7.3l IDI, Banks Sidewinder, E4OD, Baumann controller, Racer-X triple disk TC
Tags
73 , change , cover , engine , ford , fuel , good , hp , idi , injectors , mileage , motor , reliable , turbo , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
