1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2008 F450 upfitter switches dead
Old 10-30-2009, 03:56 PM
firemech's Avatar
firemech
firemech is offline
Does anyone know where the upfitter relay coil is located. i have power to all 3 fuses but the switches are dead.
Old 10-30-2009, 04:04 PM
bpounds's Avatar
bpounds
bpounds is offline
Old 10-30-2009, 04:21 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
the upfitter relays are BEHIND the glovebox
Sam
Old 10-30-2009, 04:27 PM
firemech's Avatar
firemech
firemech is offline
Thanks for the info, the coil in mention feeds the hot in run mode for the upfitter switch bank. The relays that are located behind the are all after the switches, I'm looking for the relay before all of this.
Old 10-30-2009, 04:42 PM
bpounds's Avatar
bpounds
bpounds is offline
Did you check your owners manual? It lists the user replaceable relays. If it's not listed there, then it might be built into the central junction block, and unfortunately you cannot replace those.
Old 10-30-2009, 05:36 PM
frdtruckman's Avatar
frdtruckman
frdtruckman is offline
make sure you have ignition key on
Trath67
2017+ Super Duty
25
03-19-2021 08:20 PM
farmcotton
2017+ Super Duty
55
12-29-2019 09:41 PM
Jhndere
2017+ Super Duty
12-22-2016 11:42 AM
bigcountry1009
10-27-2014 05:09 AM
mlbmd
18
04-02-2009 09:55 PM
Quick Reply: 2008 F450 upfitter switches dead
