2008 F450 upfitter switches dead - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-30-2009, 04:56 PM
firemech firemech is offline
firemech is starting off with a positive reputation.
Does anyone know where the upfitter relay coil is located. i have power to all 3 fuses but the switches are dead.
Old 10-30-2009, 05:04 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Old 10-30-2009, 05:21 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
the upfitter relays are BEHIND the glovebox
Sam
Old 10-30-2009, 05:27 PM
Thanks for the info, the coil in mention feeds the hot in run mode for the upfitter switch bank. The relays that are located behind the are all after the switches, I'm looking for the relay before all of this.
Old 10-30-2009, 05:42 PM
bpounds's Avatar
2 bit Californian
Did you check your owners manual? It lists the user replaceable relays. If it's not listed there, then it might be built into the central junction block, and unfortunately you cannot replace those.
Old 10-30-2009, 06:36 PM
frdtruckman frdtruckman is offline
frdtruckman is starting off with a positive reputation.
make sure you have ignition key on
Upfitter Switches... for what? Jhndere 2017 Super Duty 14 12-22-2016 12:42 PM
Upfitter switches bigcountry1009 1999 to 2016 Super Duty 3 10-27-2014 06:09 AM
Hook fog lights to upfitter switch? JoeWest 1999 to 2016 Super Duty 6 07-10-2009 02:49 AM
Upfitter Switches mlbmd 1999 to 2016 Super Duty 18 04-02-2009 10:55 PM
Upfitter switches Froglips 1999 to 2016 Super Duty 17 09-14-2008 09:23 PM
Tags
2006f250, 2008, 2009, 450, change, coil, f250, f450, fitter, ford, key, power, relay, switch, switches, upfitter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
