Hey all very new to the site !! its look really cool so far. I have but a few questions ? is there a way to tell witch door is making my light and dinger go off? door ajar l;ight stays on and beeping when engine not running? or can i rig it to where it goes off but does not work like maby bypass it?? thanks for repling in advance its a newbie question but i just bought the truck.. give me a break>>?? oh one more question ?? my driver side floor is taking on water is therea common awnser for this?it seems to be comming from the fire wall?
Reason: left out stuf
The switch is inside the door. Take WD40 and spray into the lock on the door and close. Do each door until you find the one that is the problem. No reason to tear into it to replace or bypass. About every 6 months just spray them down.
If I remember right - you just connect the wires together. It will now think the door is closed all the time from an electrical point of view.
Of course the light won't come on anymore when you open the door.
The water leak on the drivers side is most likely a windshield seal leak (very common on these trucks) . It is not very likely coolant or ac condensate would travel up and over the trans hump to the drivers side. If it is the windshield leaking it will probably leak into your GEM behind the fusebox soon if not already . This water in the GEM can cause all kinds of electrical problems.
You can seal the windshield yourself (you can buy a tube of windshield sealer at the autoparts store). You will need a large tube that goes in a caulking gun. Biggest problem is getting the seal back in. You will need to caulk from the top center of the windshield all the way down to the bottom of the windshield on the drivers side.
I had to use a screwdriver and lift the windshield to get that seal back in.
Or if you don't feel like fooling with it, you can go by a windshield place and have them seal it for you (not sure what the cost would be but surely no more than $50.00).
cool i will look into the windshield leak! Ive already connected the micro switches wires together still beeping im wondering if the water hasnt already caused electrical problems because i cannot get the door ajar light off, door chiming goes off when started but not light, im having all sorts of bad luck first american muscle sent me halo headlights that were made wrong and i could not install them! just getn frustrated!!!! american muscle is making it right by sending me new ones tho!
defenitly was the GEM module!! I picked one up on ebay for 25 bucks with fuse block!! thanks for your help..
