Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-30-2009, 03:35 PM
Slimsadie Slimsadie is offline
Slimsadie is starting off with a positive reputation.
Automatic transmission fluid
What brand of Automatic transmission fluid are you guys using? I am going to change out my fluid this weekend. Also is there anything else I should do to the tranny?
  #2 (permalink)
Old 10-30-2009, 07:00 PM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Adrenaline Junky
Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE.
If you're not towing heavy or have a ton of HP I would use the recommendations in the owners manual Mercon,......Mercon V is a little better yet.
Be sure to flush out the cooler. New filter too.
__________________
JIM
  #3 (permalink)
Old 10-30-2009, 10:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Former Ford AutoTrans Eng
Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold
MERCON V has replaced MERCON. MERCON is obsolete.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #4 (permalink)
Old 10-31-2009, 08:09 AM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
Fisher of Men
tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE.
Quote:
Thats what they say but I am not buying it. For years you guys (ford) were saying you SHOULD NOT use Mercon V in a Mercon/Dexron III transmission and that gloom and doom will ensue. Now you changed your mind. Not for me. Plenty of Mercon/Dexron on the shelf and I am gonna use it!
__________________
Tim
1997 F-350 CC 4x4 PSD Auto 260K
I will keep My Money, My Guns, My home and My Family. YOU KEEP YOUR CHANGE!!
  #5 (permalink)
Old 10-31-2009, 02:32 PM
MERCON V was changed to make it compatible with the 4R100. I know you won't believe me, and that's fine.
__________________
Mark
  #6 (permalink)
Old 10-31-2009, 04:51 PM
tjbeggs's Avatar
Fisher of Men
How about the E4OD? I had not heard of a change but that doesn't mean anything.
__________________
Tim
  #7 (permalink)
Old 10-31-2009, 05:30 PM
triskadek's Avatar
triskadek triskadek is offline
triskadek is starting off with a positive reputation.
Ahhh...I was waiting for the this thread to explode. I've heard so many rumors...eg all the fluids are the same now, but with the guffafle over mercon vs mercon v and big companies not wanting to look bad by changing previous statements its hard to know without being a chemist.
I've been using NAPA mercon in the PSD, but since the dipstick on the Escape says "mercon V", we used valvoline Mercon V in it.
The price difference in fluids was pretty high, but if I felt sure it was the best fluid to use, I would put the expensive stuff in the F250.
I gather the supposed difference between mercon and mercon V is V is a full synth. Now, back when full synths were new, you'd hear all sorts of things (leaking, eating seals) but supposedly now it's all magically good.
Trolling other forums will get you stories that all the mercon you can buy is actually fully synth now too, but the vendor is trying to cash in on the ambiguity issue and they have since relabeled their product as plain old mercon. Supposedly some of these vendors put out a product that was labeled as "mercon/mercon V", but sales fell because people didn't want to put mercon V in their mercon designation trans. So the vendor's solution was the re-relabing, with no change in formula.
Having no means of analyzing the fluids myself, I just go with whats on the dipstick and what NAPA has that matches.
My buddy who has a buddy who is the diesel mechanic at the ex-local ford dealership tells me they are all using mercon v now.
  #8 (permalink)
Old 10-31-2009, 07:28 PM
Quote:
No, that's not right.
You could get MERCON in dino, blend, or full synthetic. Now you can get MERCON V in dino, blend, or full synthetic.
The difference is in anti-shudder additives.
MERCON V is now compatible with ALL transmissions that used to use MERCON, including the E4OD.
__________________
Mark
  #9 (permalink)
Old 10-31-2009, 07:31 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is gaining momentum as a positive member of FTE.
Who knows what they put in mine after the rebuild. Gotta get whatever is in there out and something I'm confident using in! That and a bigger cooler.
Tj do you still have the pics Kawa sent when he did his cooler / tranny line upgrade?
__________________
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
1986 F250 6.9 XLT Gone but not forgotten
  #10 (permalink)
Old 11-01-2009, 01:05 AM
So should we be using anything different in the E4OD?
  #11 (permalink)
Old 11-01-2009, 01:51 AM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
Talking
Pete:
PM me your E-Mail address and I'll send ya what I have as well as how to stop the biggest PITA fluid leak.
Rog
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
  #12 (permalink)
Old 11-01-2009, 02:11 AM
WillySteve's Avatar
WillySteve WillySteve is offline
WillySteve is starting off with a positive reputation.
I have owned and operated an Automatic Transmission repair business for 37 years and I say it's FINE to use Mercon V in everything Ford builds. Just be sure and purchase a quality fluid, not some off the wall brand! (The type F that was recomended for years by Ford was because the old trans, years ago, had brass clutches instead of Raybestos or Kevlar linings).
I even run several qts. of 20W50 motor oil mixed in my C-6, in my 9.80 drag car. Been doin' it for years and it doubles the life of the fluid under an extreme service/extreme heat situation from a high stall converter!
Be sure and change the filter on that E40D!
  #13 (permalink)
Old 11-01-2009, 06:37 AM
Cuda_jim's Avatar
Adrenaline Junky
Quote:
Just be sure it says Mercon on the label whether you use regular "dino" oil, synthetic or a blend of the two. Again it depends on how you use (abuse) it. A bigger cooler is highly recommended to increase the life of the trans.
__________________
JIM
  #14 (permalink)
Old 11-01-2009, 10:24 AM
triskadek's Avatar
I know the usual direction of these threads is "is it safe to use mercon V in my mercon labeled trans", but honestly, the mercon v synth is a bit pricey.
While I hate to be cheap, I do like to not waste money.
Is it worth the extra price to go mercon V synth as opposed to NAPA mercon ?
My truck was used with little history of the PPO, and the PO didn't have all his service records. When I dropped the pan and replaced filter and fluid after getting it home, it certainly looked clean (and didn't smell when we were looking it over before buying it). Mr. PO claims he never had the trans rebuilt, and he tended to go to places like jiffy lube for his oil changes.
The truck has 250K miles on the odo now, and PO used to haul horses.
I want to treat the trans as best I can, but I don't know if it's a case of "put the most expensive stuff in it" or "it doesn't matter at this point, use the cheapest".
We just moved from sunny socal to the arctic tundra of eastern Ontario, CAN. I'm also telecommuting for the immediate future, so I'm really only driving on weekends to see the countryside, so there is no huge rush.
  #15 (permalink)
Old 11-01-2009, 01:28 PM
Is it a bad idea to put any after market additives into the tranny such as lucas oil treatment? I do a lot of towing so I want to protect the tranny as much as possible
Tags
4r100 , anti , fluid , mercon , shudder , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
