Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-30-2009, 03:33 PM
custom cabby's Avatar
custom cabby custom cabby is offline
custom cabby is starting off with a positive reputation.
Ford 9" drain plug damage
Ford 9" rear end.... I rounded out the female plug with my ratchet extension, any suggestions short of welding something on to it to release it? I need to replace my pinion seal and managed to bugger up the square fitting in the plug.
  #2 (permalink)
Old 10-31-2009, 02:35 AM
DLP Performance DLP Performance is offline
DLP Performance is starting off with a positive reputation.
chisel & hammer.
  #3 (permalink)
Old 11-06-2009, 12:10 PM
CougarJohn CougarJohn is offline
CougarJohn is starting off with a positive reputation.
Cabby, here's an ida that may help you:
You need to make a round hole square. Try using a Dremel tool to square up your round hole and then grind a piece of steel shock to grab your new square hole. This trick worked for me in the past though not in a rear end plug.
Tags
9 , drain , ford , plug
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
