Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-30-2009, 03:17 PM
ericds30 ericds30 is offline
ericds30 is starting off with a positive reputation.
poor accelaration
My 1986 Bronco with a 5.0 EFI automatic has no power at low RPMs in drive or reverse. Out of gear it idles fine and revs with no heasitation. In drive or reverse it feels like I am starting in a high gear if it was a manual transmition, or like it is cold and the choke is stuck if it had a carb or as if it is missing, when I get over 1500 RPMs it seems to run ok. . I have changed all fluids and filters, plugs wires and cap and roter. we checked the timiing, compression is between 140 & 150 on all cylinders, fuel pressure is at 35 at idle and increased to 45 as the RPMs increased. When we put a vaccume on the EGR it stalled the engine at 10 psi. My code reader gave a code 11 engine off. but the continous codes are 31, 53, 63 and engine running are 34 and 44. Can someone help me figure out what needs to be replaced or cleaned?
  #2 (permalink)
Old 10-30-2009, 04:19 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
what size tires are you running and what gear ratio is in your axles?. what tranny do you have AOD or C6? when you checked the timing was that with the spout connector removed and what did it show? what plugs/wires are you running. have you looked up those codes if so post up there meaning otherwise look them up at Ford Fuel Injection
__________________
94 XLT 5.8/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG MT's
4.88 gears/Aussie Front/rear open
JBA shorty, Custom Y pipe,3" exhaust
http://www.supermotors.org/registry/...il.php?id=4158
  #3 (permalink)
Old 10-30-2009, 08:56 PM
the tires are 30x10.50/15 not sure about gear ratio or tranny. all I know is it is automaitc with overdrive. we did remove the spout conector ant it was 10degrese btdc like the tag and book said. code 34 is defective EGR presure sensor and 44 thermactor air system fault. The problem started suddenly a few days ago and is only in gear at below 1500 RPM
  #4 (permalink)
Old 10-31-2009, 03:24 PM
if you have OD then you are running an AOD. sounds like your TV cable needs adjusted. I would take it to a shop and have it done there because if its not done correctly you will fry the tranny FAST.
__________________
Tags
accelarating , f150
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
