Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-30-2009, 03:08 PM
97nukeford's Avatar
97nukeford 97nukeford is offline
Nebraska Chapter LDR
2006 Ford F-250
My Garage
97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of 97nukeford has much to be proud of
5 speed tranny swap on an FE
I am installing a 390 in my 67 F-100 4x4, and I'd like to install a later model (80's-ish) 5 speed and transfer case from an F-250, probably one off of a 460 truck. First of all, what tranny's did these trucks have, and can they be adapted to the FE motor? Thanks!
__________________
Pat W.
Nebraska Chapter Leader and Official #2 Slackmaster!
2006 F-250/ 1997 F-150/1967 F-100
1967 F-100 Project
GO HUSKERS!!
CLICK HERE TO JOIN THE NEBRASKA CHAPTER!
  #2 (permalink)
Old 10-30-2009, 05:06 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
The ZF transmissions used in F250 and up behind either a 351W or 460 have integral bellhousings in the patterns of those two engines. They will not bolt up to an FE. It was SAID there are adaptors in the following thread, but no link to anyone selling such a thing. Forget the ZF, go for an NV4500. Oh yes, note the Clark being mentioned. Most are 1:1 in high, most are worn out, most are at the bottom of a scrap pile, and all require modifications to an FT flywheel and a host of other minor details.
http://www.ford-trucks.com/forums/88...ml#post7950042
Note there are links in that thread that take you to a company with info/parts/adaptors for the NV4500 into a Ford.
  #3 (permalink)
Old 11-01-2009, 12:14 PM
DeepRoots DeepRoots is offline
DeepRoots is starting off with a positive reputation.
If it was me, I'd put in a Tremec tko or t56
__________________
'89 Ford F250 7.3 Diesel, used to be c6 I stuffed a zf5 in there now, ATS 088 turbo, 3.55rear, 2wd. Moosepump
  #4 (permalink)
Old 11-01-2009, 12:18 PM
97nukeford's Avatar
2006 Ford F-250
My Garage
If I could afford a tremec, that would be great! I may just have to look into either the 4500, or just having mine re-geared. I have no need for a granny gear. Still would like to find a 2 speed transfer case for it.
__________________
Pat W.
1967 F-100 Project
GO HUSKERS!!
Tags
390 , 428 , ford , nv4500 , speed , swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
