Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 10-30-2009, 12:51 PM
Jeepincj7's Avatar
Jeepincj7 Jeepincj7 is offline
Garage is empty, add now
Jeepincj7 is gaining momentum as a positive member of FTE.Jeepincj7 is gaining momentum as a positive member of FTE.
No cruise or horn. NOT the clock spring though
Well, I just got done swapping out the clock spring on my Excursion because the horn and cruiser will not work. Still having the same issue now and I know I did it correctly. So, what else is left?
I will say that the horn engagement seems really wierd on this. Its like its not spring loaded at all. Normally when you push a horn it will feel as if there is a spring, but not on this X. I am curious if that may be the issue or may have something to do with it.
I have also check fuses as well and they are good.
FWIW, the airbag system is working correctly and the horn will sound with the alarm, so I know its working. Any ideas?
__________________
Scotty
2001 Excursion 4x4. 7.3L, 4" Lift, 35" Toyo M/Ts, Racelines, DP Tuner, Glowshift gauges, Roadrunner Torque converter, Diamond Eye exhaust, RAS, etc
1994.5 CC, LB DRW, 2wd, 7.3L, 5spd. Stage 1's, Valair clutch, Diamond Eye exhaust, 7.3 intercooler, PHP Hydra chip, gauges.
  #2 (permalink)
Old 10-30-2009, 02:29 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.BillyBob69 has a great reputation on FTE.
Remove the steering column cover and check the wiring that runs along the top. They have been known to chafe and break. Especially with those that have tilt.
__________________
99 F350SD Lariat Crew Cab 7.3L PSD - 4x4 - DP Tuner - Custom HD trans
86 Bronco 302 EFI (Second one!)
Quit whining! You voted for him!
http://i86.photobucket.com/albums/k102/billybob69_photo/90x90_email_signature_HIGHMILER-1.png
  #3 (permalink)
Old 10-30-2009, 03:32 PM
Jeepincj7's Avatar
Quote:
Will do, and will report back shirtly.
__________________
Scotty
  #4 (permalink)
Old 10-30-2009, 04:08 PM
Jeepincj7's Avatar
Wiring looks fine. Casing still intact and no indication of any wear issues or chafing other than this issue on my ***.
__________________
Scotty
  #5 (permalink)
Old 10-31-2009, 01:51 AM
wallz's Avatar
wallz wallz is offline
2002 Ford Excursion
wallz is a splendid one to beholdwallz is a splendid one to beholdwallz is a splendid one to beholdwallz is a splendid one to beholdwallz is a splendid one to beholdwallz is a splendid one to beholdwallz is a splendid one to behold
I had a similar thing happen last winter. I ended up giving up and taking it in. They replaced the wiring on the brake master cylinder, (on the end of it there is a wiring harness) and then they traced it to the cruise control module. There is a recall for that switch on the brake master cylinder so you can phone in your vin and they should be able to tell you if it was ever upgraded on yours, or take it in and they can look at it and should be able to tell. Mine was replaced, and still had the same problem.
Here is a picture.
Click the image to open in full size.
__________________
2002 Excursion, 4x4, V-10, XLT, RS9000 shocks, true trac diff, 08 alum diff cover, interior light delete, 08 power fold/xtend mirrors, 285/75/16 BFG KM2 tires, y pipe, 5 Star tuned, front cryo powerslots with hawk pads, XRF ball joints. 50" front mounted LED bar, 10" reverse light LED bar. Banks stainless long tube headers and exhaust kit.
  #6 (permalink)
Old 10-31-2009, 08:50 AM
Jeepincj7's Avatar
Quote:
Here is a picture.
Yes, mine has been replaced in the recall. Since I have only had this X for a couple weeks, I have no clue if it worked before or after that. Oasis report doesn't show squat either.
__________________
Scotty
  #7 (permalink)
Old 10-31-2009, 10:47 PM
wallz's Avatar
2002 Ford Excursion
Well if you replaced the clock spring, and already had that wire done, the only thing left would be the cruise control module. The most expensive part in the mix.
__________________
  #8 (permalink)
Old 10-31-2009, 10:54 PM
twall_SD250's Avatar
twall_SD250 twall_SD250 is offline
2001 Ford F-250
twall_SD250 is starting off with a positive reputation.
it is the cruise control module.. it happen to me.. had the wire harness off the master cylinder replaced and then found out the the module was burnt out at the connector... it cost like 300 for the part if im not mistaken.... if u disconnect the module and disconnect the wire harness by the master cylinder and make sure all your fuses are good the horn will work
  #9 (permalink)
Old 10-31-2009, 11:00 PM
2001 Ford F-250
if the module is bad the wire harness that goes to the mater cylinder is no longer needed because that harness is for the cruise control only... i forget the correct term of the harness is called but i will look it up and get back to you on it
  #10 (permalink)
Old 11-01-2009, 03:44 PM
nghtrgr's Avatar
nghtrgr nghtrgr is offline
nghtrgr is gaining momentum as a positive member of FTE.
where is the cruise control module you speak of???
__________________
2005 Ford EXCURSION-6.0L Powerstroke Diesel
ATS Headstuds, Airaid Intake w/Zoodad, ITP Reg Rtn, MBRP Turbo Back, 3 Guage Overhead Pod, Heat Extractor Hood, 4-6" Lift, 35" Mickey Thompson Baja MTZ's on MT Classic Locks, FS2500 Bypass System,
DFUSER Light Harness, DFUSER Coolant Bypass Filter
CCV Reroute
  #11 (permalink)
Old 11-01-2009, 07:14 PM
Extland01 Extland01 is offline
Extland01 is starting off with a positive reputation.
I have the same issue on a 2001 f 250 4x4 lariat. its a standard shift and the horn will only work with the ignition off and the shifter in reverse. It also works with the alarm.
  #12 (permalink)
Old 11-01-2009, 09:16 PM
2001 Ford F-250
The cruise control module is located on the passengers side fender right in front of the A/C unit. My module burnt out were the wire harness plugs into the unit. If u don't want to get it fixed because you don't use the CC the just unplug the brake switch harness that plugs into the master cylinder and make sure the fuses are all good and the horn should work. I will check tomorrow to see if I still have some pics and info on all this
  #13 (permalink)
Old 11-02-2009, 04:41 PM
i unplugged the module and noticed the burnt marks on the harness and then I unplugged the master cylinder..........still no horn. Works great while my standard shift is in reverse and it also works with alarm.
  #14 (permalink)
Old 11-02-2009, 05:10 PM
nghtrgr's Avatar
__________________
CCV Reroute
  #15 (permalink)
Old 11-02-2009, 06:11 PM
2001 Ford F-250
the cruise control module is located on the passengers side fender infront of the A/C compressor
Tags
1997, 1999, 99, check, clock, clockspring, diesel, duty, f150, f250, ford, horn, replacement, spring, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
