Ok guys I've got a bit of a dilema, in a good way. I've got a 2wd 97 running 3.55s with a 6637, 4" downpipe and the rest is stock. Over the past year I've managed to average 17.8mpg in town and and 21.6 over the highway with a few trips up to 23mpg I cruise at about 72-73mph. These are all hand calculated. It seems as though this is about as much mpgs I could squeeze out of the truck. The tinkerer in me wants to throw on a less restictive exhaust and possibly a chip, but I'm pretty happy with what I've got now. If MPGs are my main goal I'm scared that more mods might adversly effect what I'm getting now. When chips say they offer a stock setting is it exactly that, or is it the new chips version of a stock setting? I hope to hear some advice, keep in mind I'm after MPGs, but also wouldn't mind a little kick in the pants every once in a while.
Hi MaxRedD90! Welcome to FTE! Here is a very cool site for ideas: Tips - Idea - Hints Exhaust and air Mods are what I would do 1st!
__________________
97 F350 7.3L Auto 4WD Crew Cab 200K. Another OFFICIAL six point slow recovery vehicle! MODS: HOOOOGA! horn, PO MAN's air intake, Service/Utility bed, 3" DP, Testing that Cat, FPR shim (whoknows PSI), 140v IDM, 2 10K pots.
US ARMY OAS, OJE-IFOR, SFOR,2,5, OJG-KFOR, OIF, OEF. To ALL that have served, THANK YOU!
If you don't have a better HPOP I've heard that it will help your MPG's. I recommend a Adrenaline HPOP from dieselsite.com
Good pumps and your truck will run much smoother and better
__________________
Brownie, Ooh-Rah! USMC Member of the NRA!
'95 F350 CC 4x2 - SRW Swap, E40D, PHP 6 Pos. Chip, 6637 mod, 3" D.P., Lost Kitty, 140v IDM, HPX Mod, FPR Shim (65 psi), T.C. switch, 3.55 gears
'88 F350 CC 4x4 - lots of dents, faded paint, old 7.3 IDI in pieces
Ya with stage 2 injectors and everything else i can still pull 21mpg on the highway(hand calculated of course). that is only when i can keep my foot out of it long enough to do that which is only on long trips when i set the cruise at about 65-70mph. i would get you a chip with a good economy tune and tow tune if you tow a little bit at least. if you want that kick in the pants here and there get you a good performance tune. best places for chips are www.totaldieselperformance.com, DP-Tuner, or Power Hungry Performance - Feed your hunger for POWER! Check out our Gryphon Programmer for Ford vehicles!.
i would also do the exhaust all the way back with 4" or 5" pipe w/out a cat and a good performance muffler or no muffler at all if you like the sound. LoL.
get you some boost and egt guages. boost guage is kinda nice b/c you can look at how much power your making the engine use by checking the boost level. the more boost rises the less MPG your going to get. if you keep the boost wayy down low you will get better mileage. egt is just to keep from burning up the engine
now get you a better high pressure oil pump(HPOP). adrenaline claims good MPG improvments, as do some of the users of the adrenaline.
you and me talyn. but i use my 4 wheel drive a lot and I would never trade it for another 5-6 mpgs. I know i can do some things to improve mine ,but I know I will never see more than 18
__________________
1997 F-350, 4X4, Standard Cab, Long Bed, 4.10's
4wd is what i will have next. i don't like not having it when i need it!!!! this will probably be one of my last 2wd trucks. i love my truck but it would be SOOO much better if it was 4wd!!!
Maxred,
I bet you could easily get a couple more mpg with small skinny tires up front, skinny tires in the rear, and dropping the whole truck 2" or 3". Add a small wind dam under the front bumper, a cover on the bed, maybe drop your rear end ratio, and keep your foot out of the throttle.
I bet you'd be amazed at what you can pick-up doing these things. I planned on doing all of the above to my '97 cc 2wd, but the torch had other ideas and the truck is a dedicated drag truck now.
__________________
'96 F-350 Reg Cab 4x4 PSD
'97 F-350 CC Short Bed 4x4 PSD
Wow guys for my first post I'm so glad to get such great information. I live in the south Ga area and do most of my driving in Florida thus 2wd and flat terrain help MPGs. Looks to me like the worst downfall with mods is that it takes more discipline to keep the right foot conservative. I like to keep an eye on things before changing mechanics so guages are going in first, then exhaust. That'll be stage one.
__________________
To be honest with you I had horrible milage when I was bone stock, all the basic mods are very complimenting, the filter was first on the list, sounds cool and its peice of mind, then I did a down pipe following straight open ewxhaust to the stacks after that, with a chip, bone stock I could not get more than 230 miles out of 18 gallons according to hand calculations, when I got the chip I went to 260-280 pertank and now with the exhaust I'm at 279 miles and I still have a quarter tank left, I'm guessing about 315 a tank with all the mods, I'm also running 3:55s and 4x4. Id say that's a hell of a difference, I run a 100 hp dailey driver aswell. As long as you stay out of it, id say you can hit 24 or 25 mpg highway and 20 around town. Also the difference in the truck running with and with out the chip is amazing, it just physically starts easier,faster and its very responsive
__________________
red 7.3 powerstroke diesel-6637-10k-6 POS chip big name tunes-HPX line-3" Downpipe--> 6" Aussie stacks! 3:55s auto-122k miles-Rotella Synthetic, ebpv butterfly removed
