Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2010 6.4L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2008 - 2010 6.4L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-30-2009, 06:26 AM
OBX Powerstroke OBX Powerstroke is offline
OBX Powerstroke is starting off with a positive reputation.
Black Soot = Bad Injector?
I have been dealing with black soot in the tailpipes for about the last 8k miles. First trip to dealership, they "checked" everything and could not find a problem. Said keep an eye on it and at next oil change if it's still black, we'll dig deeper. Well, took truck in Tuesday evening and dropped off for service work because I also experience a "shudder" some mornings when the engine is cold. They wanted it at night so they could check the shudder when the truck was cold which makes sense since it does not do it when the engine warms up. Got a call yesterday that they think they found the problem with the shudder and black soot - I have one bad injector. My question to you who know diesels is, could a bad injector cause both these problems?
Thanks for any input in advance.
  #2 (permalink)
Old 10-30-2009, 06:40 AM
ruschejj's Avatar
ruschejj ruschejj is offline
2008 Ford F-250
ruschejj is starting off with a positive reputation.
I am no expert but if the injector is causing an over-fueling condition then it is likely that it is causing the extra soot production. How it gets past the DPF is the magic question.
The shudder happens under numerous conditions. Points to CAC problems, MAF, boost limit, overall engine limits under heavy load. The two conditions could easily be non related.
__________________
'08 F-250 4X4 CC 6.4
RideRite Airbags in Rear w/onboard compressor
Bilstein Shocks, Dual Air Horns (under hood)
Edge Insight Gauge Cluster
4-Way "wig wag" strobe lights
Polk speakers, Kicker 10" sub, 600w amp
  #3 (permalink)
Old 11-05-2009, 09:17 PM
SANDDEMON08's Avatar
SANDDEMON08 SANDDEMON08 is offline
FORD POWERSTROKE JUNKY
SANDDEMON08 has a good reputation on FTE. SANDDEMON08 has a good reputation on FTE.
One bad injector would give you enough of a bad performance issue to be obvious(rough idle, poor performance, bad milage, ect. Im thinking you could have a cracked DPF which was a common problem that lead to the soot issue seen in the tail pipe.
Has the sudder always been there or does it shows itself more when the truck is loaded?
__________________
http://www.ford-trucks.com/user_gall...photoid=158114 Got beer ? 498HP 965
2008 F350 SD CC FX4 ON 20's, 6.4 PSD,TORQ-SHIFT,3.73 REARS, NAV, BLACK LEATHER SEATS,DASH DAQ GAUGES, AFE STAGE II INTAKE,SPEARCO INTERCOOLER,CUSTOM TUNING, SEIC MOD,AMP REASEARCH STEPS, LINE-X SPRAY IN BED LINER, T-REX BILLET SIDE VENTS.
  #4 (permalink)
Old 11-06-2009, 07:47 AM
Just got truck back yesterday and they found 2 issues; 1) #3 injector was bad and was replaced, 2) DPF was cracked and was replaced. Great service from Courtesy Ford in Elizabeth City, NC.
Shudder only shower up going from 20mph to highway speed. Diagnostics showed #3 & #4 injector cutting out at highway speeds.
  #5 (permalink)
Old 11-06-2009, 08:27 AM
senix's Avatar
senix senix is offline
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
great that they got it fixed. Strange how you had both issues at the same time.
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #6 (permalink)
Old 11-07-2009, 10:57 AM
Quote:
I agree, kind of unusual they both happened at the same time. Just glad my dealer took the time to make sure both problems got fixed correctly. I was without my truck for 10 days, but they gave me a loaner F-250 V10 so it was OK. I did notice upon getting my diesel back the difference in power between the two.
  #7 (permalink)
Old 11-07-2009, 10:34 PM
RoadJunkie RoadJunkie is online now
RoadJunkie is starting off with a positive reputation.
Quote:
Is there any of us that has not heard a similar response from a service adviser? Or, it's "normal" to do that, sound like that, or look like that? I believe the hope is that the customer will give up and live with the issue. Anyway, glad they found your problem.
  #8 (permalink)
Old 11-18-2009, 12:50 PM
Well, to report back, I have put 1500 miles on the truck since the work was completed and exhaust pipes are completely clean, not black soot whatsoever. YEA! Also, shudder is gone and truck definately seems to have a little more power. Fuel mileage is a little better with the new injector, about .5 mpg better. So far, all is well.
  #9 (permalink)
Old 11-18-2009, 06:43 PM
senix's Avatar
great report!
__________________
  #10 (permalink)
Old 11-18-2009, 08:14 PM
cheezit cheezit is offline
cheezit is gaining momentum as a positive member of FTE.
not starnge at all that the injector would cause a dpf failer. The overload of the fuel can cause higher then expected temps and make that happen.
Tags
150 , 64 , bad , black , clicking , diesel , f150 , ford , injector , injectors , issues , load , powerstroke , problems , soot , tailpipe , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
