Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-30-2009, 05:25 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
1993 Ford F-250
FORDF250HDXLT is starting off with a positive reputation.
headers+turbo?
Quote:
Originally Posted by greythorn3 View Post
heres a pic of the headers for the 6.9 idi ford from stans.
Quote:
Originally Posted by Kleenax View Post
Would probably be a million less headaches and not much more $$ to have Stan fabricate a custom header for a turbo installation since he already has all of the equipment to do the fabricating & layout. Doesn't cost anything to talk it over with him anyway!
Quote:
Originally Posted by lumbermansvo View Post
I'm emailed him about a turbo header, he wont do it, says it can't be done. He will make crossover pipes for turbo setups though.
why couldn't you run a 3" down pipe from the turbo into a custom built 3 inlet collector after the Y?
1.not enough room?
or 2.the turbo simply couldn't work with an extra long down pipe? if so,why not?
or 3.this is a totally unrealistic thinking,and i clearly have no clue how turbo's work lmao.(i know the latter part of 3 is correct lol)
research gathered from this thread:
http://www.ford-trucks.com/forums/54...6-9-7-3-a.html
__________________
1993 F250 Heavy Duty 4x4 XLT, regular cab, two tone with red interior, 444CID/IDI/NA International Diesel, E40D auto, 1356 BW manual shift TC, Dana 50 TTB front/Ford-Sterling 10.25 2nd-gen full floater rear with 3.55:1 gears.That's stock.See my garage for mods. 47k original miles. Carfax clean w/last OR 29,200 in '06. Not yet on the road. Brand-new to me.
Real Trucks Don't Have Spark Plugs.
  #2 (permalink)
Old 10-30-2009, 07:24 AM
tjc transport's Avatar
tjc transport tjc transport is offline
oh no, not again!!
tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation.
you would need to make a y pipe after the headers, then one really long up pipe to the turbo, then a down pipe.
headers improve flow over stock manifolds, to give you better exhaust scavenging.
a turbo combines both exhaust sides to spin the impeller.
in my eyes, that would defeat the gains of the headers.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of way too many fords.
  #3 (permalink)
Old 10-30-2009, 07:35 AM
DeepRoots DeepRoots is offline
DeepRoots is starting off with a positive reputation.
technically using multiple pipes up to a turbo is called a pulse turbo.
This does benefit the turbo.
Of course we have a large engine in limited space with a turbo that typically only make 10psi at wot.
I doubt it'd be worth the trouble in a pickup. But it *would* be better.
__________________
'89 Ford F250 7.3 Diesel, used to be c6 I stuffed a zf5 in there now, ATS 088 turbo, 3.55rear, 2wd. Moosepump
  #4 (permalink)
Old 10-31-2009, 12:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
In that picture the passenger side manifold, turbo up pipe and exhaust Y are already installed.
You can see the studs sticking down from the Y and the drivers side manifold where the cross over bolts up to.
When you look at that picture think about how much volume of exhaust it will take to fill and also how close the turbo is to the cylinders.
Now look at the headers, figure in a cross over, do a 180 degree change in the exhaust path and get it back up to the turbo through this hole.
While thinking about that, I have a 2" body lift installed to have that much room between the engine and firewall so I did not have to cut the firewall to install the 3" down pipe.
And the last thing that enters into the turbo equation is exhaust heat.
The more heat you loose before the turbo, the slower it spools.
So now you have added lots of extra volume to fill with the header tubes, cross over and up pipe, and lots of extra length to the pipes so more heat can escape before the exhaust reaches the turbo.
So you added a huge amount of turbo lag till the headers and up pipe can build pressure and heat to spool the turbo.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #5 (permalink)
Old 10-31-2009, 01:21 PM
dyoung14's Avatar
dyoung14 dyoung14 is offline
1986 Ford F-250
dyoung14 is starting off with a positive reputation.
those headers are designed for n/a use, not turbo use, there is a guy on oil burners trying to develop and sell both n/a and turbo headers, if you have some that are designed to work with a turbo it will boost a worlds difference, i talked to a guy with a custom set of turbo headers and a hypermax pulse turbo and he said it spools almost exactly like a wastegated turbo and that hes pushed past 15 psi but then got afraid
__________________
1986 ford f250 XLT Lariat 4x4 6.9 n/a, t19,285/75/16 maxxis mudders, on gun metal grey wagon wheels,Brand new BB code injectors from typ4, rebuilt ip set to 4??? rpm, really advanced timing, glow plug delete mod, soup bowl and restrictor plate gone, equis performance water temp, and oil pressure gauges, factory tach, putting a non wastegated psd turbo on it very soon, and going to run isspro boost and pyro gauges and maybe isspro tach along with factory tach just for kicks and giggles
Tags
180 , 69 , 69l , 73 , 89 , diesel , f150 , ford , header , headers , headersturbo , idi , price , run , turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
