Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 10:27 PM
branden.w's Avatar
branden.w branden.w is offline
branden.w is starting off with a positive reputation.
NEED HELP!!!!
ok i just put my motor back together after replacing the glow plugs, injectors, vacuum pump and some other things. i tried to turn it over and i get nothing, it turns over fine and even fired for about 4 seconds then died, the timing is correct i know that, other than that i dont know where to start, its a 6.9 banks turbo diesel.
  #2 (permalink)
Old 10-29-2009, 10:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
Charge the batteries, loosen several injection lines, crank the engine over and bleed the air out of the injection system.
When you get fuel back to the injectors, tighten the fuel lines, let the glow plugs cycle and it should fire off.
Caution, 20 seconds is the max cranking time, then 2 minutes cool down time for the starter before cranking again.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #3 (permalink)
Old 10-29-2009, 10:51 PM
branden.w's Avatar
i think i blew the starter trying to turn it over too much, i was thinking about loosening the injector lines though for sure, i dont think its that simple though, cause when it started for a second it was damn near redlining. anything else maybe?
  #4 (permalink)
Old 10-29-2009, 10:52 PM
morimoto_87's Avatar
morimoto_87 morimoto_87 is offline
1991 Ford F-250
morimoto_87 is starting off with a positive reputation.
I'm not a diesel mechanic but from what i do know is when you replaced your injectors you got air into the lines so it may take some cranking to get all that air out...if possible you should have someone crank the engine while you bleed the system..You can do this by pressing the schrader valve(tire valve stem) on the fuel filter housing...I beleive the 6.9 you have is the same as the 7.3 i have as far as the mounting of the filter...when you see diesel start spurting out as it is cranking you have bled the system up to that point...NOTE: DO NOT RUN THE STARTER FOR MORE THAN 20 SECONDS AT A TIME...Wait 2 mins after cranking to let the starter cool off..
NEXT: Did you have the new injectors pop-tested? If not the problem may lie within the injectors...
Hope this helps...if i'm wrong on this, i'm sure someone will be behind in a bit to correct me.
__________________
1991 F250 with a bignasty 7.3 IDI n E4OD, 3:55's, 285/75/16 UNIROYAL RADIALS
  #5 (permalink)
Old 10-29-2009, 11:10 PM
JesterPgh's Avatar
JesterPgh JesterPgh is offline
1987 Ford F-250
My Garage
JesterPgh is starting off with a positive reputation.
Even if it ran shortly, but was basically running away, that really points to air in the lines. Dave S. knows these IDIs, so I'd definitely check into what he's said. If I run mine too low on fuel, I get air intrusion, and it will run away, seems like it's going to frag itself. Did you fill the fuel filter with something (diesel fuel, diesel kleen, atf?) prior to trying to start it the first time?
__________________
Jim
____________________________________
1987 F-250 4x4, 6.9 ATS turbo, 4 spd
1993 Lincoln Mk VIII, coil spring conversion, 4.6l of fun
  #6 (permalink)
Old 10-29-2009, 11:28 PM
branden.w's Avatar
i just put stacks om it to, so i really wanna hear her run!!, lol
  #7 (permalink)
Old 10-29-2009, 11:32 PM
branden.w's Avatar
i was thinking air in the lines to cause i know diesels are really sensitive about that. i will check it out tomorrow for sure, i got worried though cause when it did start it was like redlining for two seconds then died, and where can i go to get my injectors tested? they are brand new so does that make a difference?
  #8 (permalink)
Old 10-30-2009, 02:18 AM
branden.w's Avatar
the fuel filter is full of 90% diesel and 10 diesel kleen. and to the best of my knowledge all the air is bleed out of the lines. so i dont know, im taking it back apart tomorrow so well see what happens.
  #9 (permalink)
Old 10-30-2009, 02:28 AM
David85's Avatar
David85 David85 is online now
David85 is gaining momentum as a positive member of FTE. David85 is gaining momentum as a positive member of FTE.
Did you remove the top cover of the injector pump?
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel, Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #10 (permalink)
Old 10-30-2009, 02:53 PM
branden.w's Avatar
I didn't Take the cover off the injector pump. Should I?
  #11 (permalink)
Old 10-30-2009, 03:34 PM
tbone91 tbone91 is offline
tbone91 is starting off with a positive reputation.
Quote:
No.
David85 is asking to be sure you didn't. If reassembled wrong, it could lead to destructive run-away. I don't know the details, as it's about the only mistake I haven't made.
My guess is that you bumped one or more of the return lines and now they are letting air in. Once you get it running again, if it starts and then dies after sitting all night, then you'll probably need a return line kit...
Good luck and hope your starting is not toast.
__________________
91 F350 dually crew cab, Rebuilt E40D + TC, ATS turbo, stock intake & exhaust
  #12 (permalink)
Old 10-31-2009, 12:09 AM
branden.w's Avatar
the solenoid on the starter is done i ordered another one though, i got a brand new return line kit and there are no leaks, ive double checked everything and replaced so many parts, i dont know what to do anymore, lol all this help is awesome though guys, thanks
  #13 (permalink)
Old 10-31-2009, 01:34 PM
1986 Ford F-250
Air in the injection lines causes to much fuel to be injected as long as there is some fuel in the lines.
Fuel can not be compressed, air can.
With just fuel in the lines, the injectors pop open, pressure drops quickly and the pop closed.
With fuel and air in the lines, air compresses, so the injector pops open, air expands keeping the pressure high longer before the injector pops closed.
Once the fuel is replaced by air only, there is nothing for the engine to run on.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
