Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 10:03 PM
bigbugman bigbugman is offline
bigbugman is starting off with a positive reputation.
spring swap
does anyone know if the front springs from an early 99 model (the early style springs) will fit on an 02 model excursion (same frame as a super duty) it needs new springs and got a good deal on these. Thanks for any help.
  #2 (permalink)
Old 10-31-2009, 12:28 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler is starting off with a positive reputation.
im almost 100 percent that the springs are the same i do know that 99 and some early 00 trucks have different u bolts and front spring perches. i think they are round instead of squared but the springs are the same.
__________________
04 F-350 SC, SB, 4x4, V8, Auto, 4.30 gears,
K&N intake with pre wrap, 1714 Super Chip programmer, Gibson SS headers, e-bay y-pipe, high flow converter, pro chamber muffler, custom add a leaf, dually camper leaf
1978 F-150 4x4 351M stock for now (my new hunting rig)
  #3 (permalink)
Old 10-31-2009, 06:42 PM
suzuki0702's Avatar
suzuki0702 suzuki0702 is offline
suzuki0702 is starting off with a positive reputation.
check it out because they switched axles!!!
__________________
2004 F250 CrewCab, FX4 Off-road, 5.4, K&N FIPK, Jensen 7" TFT flipout touchscreen, Whelen Hideaway strobes, 1650 CCA dual batterys, 8' 6" western proplus
  #4 (permalink)
Old 11-01-2009, 07:58 PM
Flatdeck's Avatar
Flatdeck Flatdeck is offline
Flatdeck is gaining momentum as a positive member of FTE. Flatdeck is gaining momentum as a positive member of FTE.
If it helps, I put 2003 F-350 V-code springs into my early-1999 F-350; no issues.
__________________
Greg :: PAA#55
1999.0 F-350 4x4 PSD SRW reg cab, auto, manual xfer case, Warn manual hubs, aluminum flatdeck, VB springs, 2" zero-rate front levelling spring pack, Predator tuner, LT265/75R16E, 2003 40/20/40, Sirius Starmate 3
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
