Still pulling parts off of my 94, almost ready to convert my 89 f350 2wd drw to a 4wd and I'm sure that the gear ratios are different.
What opinions do you guys have on swapping the SRW also so the gears match. I'd loose the two extra wheels but......
The main use of my truck is to pull my curbing trailer (12,000 lbs) and occasionally haul rock or dirt for landscaping jobs.
I'm not that attracted to the dually part of the truck as I mainly purchased it for the dump box and the crew cab.
Goodie! Ya gotta keep the dual wheels, if anything ya always got two spare wheels on the ground. Also Dave is correct on the degraded stability if ya go SRW.
__________________ Real trucks rattle! '90 F350 XLT Lariat, reg cab, dually, RWD, 4.10s, factory tow package, and lots of add-on goodies.
Quote:
Originally Posted by 94shorty
Check codes BEFORE throwing money at replacing perfectly good parts. Slowly and systematically, test, confirm related items are working correctly.
