Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 09:25 PM
lhud lhud is offline
lhud is starting off with a positive reputation.
2002 7.3 DIED WHILE DRIVING TODAY
Help Fellow FTE Folks,
Truck has 329K + and lately it has sort of hickuped numerous time to and from work - not a miss, but more like an electrical interuption, a jerking of the engine.
Today coming home, it just died. Pulled over swapped out a good (?) used CPS since the tack would not move when I tried cranking. Still no start.
Got the wife to bring me a brand new CPS (grey one) and installed that one, still no crankie. So I had it towed home.
At home I hooked the AE to it. Had a couple of codes from the overhead module problem I fixed last week with some loose surface mount resistors, so I cleared those codes - nothing else.
I tried the injector buzz test - would not do that test.
Tried the KOEO test - still nothing. Had to close the program each time to exit the program to do the nest test.
I have done both these tests in the past and they worked easily and responded.
Tomorrow if it does not rain, I plan to start checking fuses, etc. and whatever else you folks might suggest.
The batteries are new and the engine turns over very well.
Oil levels and fuel levels are good. Filter and oil change recently.
No check engine lights appeared.
Thanks for any suggestions.
  #2 (permalink)
Old 10-29-2009, 09:31 PM
mndiesel's Avatar
mndiesel mndiesel is offline
USAF 84-90
1999 Ford F-250
mndiesel has a good reputation on FTE. mndiesel has a good reputation on FTE.
Start with the fuses and maybe see if that area is wet. I have heard that sometimes the windshield can leak and it runs right down the firewall to the fuses. It has been wet down there the last week or so so I would start there.
__________________
Tom 99.5 f-250 7.3 sd ec, 4x4 many mods
Minnesota Chapter Leader
Join the MN chapter Here
Join the Roadside help Network
  #3 (permalink)
Old 10-29-2009, 09:56 PM
I agree MNDIESEL, that's an easy starting point.
Thanks,
  #4 (permalink)
Old 10-29-2009, 10:00 PM
F350-6's Avatar
F350-6 F350-6 is online now
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Tach will not bounce on the 02 model, so no luck there. No codes and no tests with AE. Any mods (chips) to the truck? Can you monitor live data with AE and just not run tests, or is it all shot?
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #5 (permalink)
Old 10-30-2009, 01:33 AM
flatbeder's Avatar
flatbeder flatbeder is offline
Just Truckin
flatbeder is gaining momentum as a positive member of FTE.
subscribing
__________________
BIG JOE
2000 F250 PSD Extndcb SB 2wd bone stock (not for long)
1986 F-250 4x4 RC 2sd owner 460 C6 some mods
  #6 (permalink)
Old 10-30-2009, 01:49 AM
Rockrunner86's Avatar
Rockrunner86 Rockrunner86 is offline
Rockrunner86 is starting off with a positive reputation.
Wierd. I would check for loose connectons (plugs, main harness plug also.)
This will be a interesting thread. Hope it gets figured out quickly.
__________________
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Terminator Engineering
Fuel Swamps 250cc B-codes
  #7 (permalink)
Old 10-30-2009, 08:21 AM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is gaining momentum as a positive member of FTE. riverrat41 is gaining momentum as a positive member of FTE.
subscribing
__________________
Barry.....FISH HUNTER!
Tony Wildman Chip , 4''Exhaust, 6637w/Pete's Cover, Crossover, AIH Delete, Foil Delete, WW, Ped Gutted, Tugger Kit, Isspro Gauges, CCV, Recon smoke cab lights, Camo seat covers, Replacement Bumpers, Hutch/Harpoon ,Cold A/C Mod, True Cool
  #8 (permalink)
Old 10-30-2009, 08:34 AM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Getting Faster...
Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of Izzy351 has much to be proud of
Yep -- you can't test the CPS with the tach like the pre-'02 models. No start means no HP oil or electrical, mostly. Can you see your ICP? When I changed out my injectors, it took several cranks to get it over 500 psi for it to fire. The second I hit 500, it fired. How are your batteries? They have to be over 10.5V to start.
__________________
  #9 (permalink)
Old 11-01-2009, 06:54 PM
Update!
Haven't forgotten about you guys.
Last Friday I finally was able to pull some codes - P1663, P1667 & P1668.
I could not however get the AE to perform the injector buzz test, so I unpluged the fuel bowl heater from the inside of the bowl - still no start.
Checked all the fuses under the steering wheel fuse box with a VOM - all O.K.; even swapped a couple of relays there as well - still no start.
HPOP oil level is fine. Also replaced the accelerator pedal since I had a spare - still no start.
I also made sure my fuel pump was coming on when the key was turned on; also opened the drain valve on the fuel bowl and ran the pump - noticed I had more flow with the pump on than without, but was not impressed enough with the pressure difference.
I had ordered a new Walbro, 255LPH pump and it came in late Friday after I had the truck towed to the diesel shop. Would have replaced it but did not get the chance.
Since it is my work truck I wanted to attempt to fix it before having to turn it over to my local diesel shop (not the stealership) who has a very good reputation around here before it got too late on Friday of last week. With rain called for on Saturday, I was not going to have a full weekend to check things out - bad deal.
So, on Saturday I started reading through my Ford shop manuals, expecially the "Powertrain Control / Emissions Diagnosis manual. Wow, it has a lot of good stuff.
I am now suspicious of the fuel pump with the high miles on the truck, so my "Guess List" is going to be:
1. Fuel Pump Failure
2. UCVH Failure or Failures
3. IDM
4. PCM
I know this is long, but since there are numerous posts for similar problems and no real follow up with the solution, I wanted to keep you up to date.
I expect the shop to call me tomorrow or Tuesday at the latest with their diagnosis.
It frustrates me that I gave up too easily with the trouble shooting procedure, especially after I read through the manual.
Thanks Fellow FTE Guys,
__________________
2002, F250, 7.3 PSD, 4x4, CC, SB, Gold Superchip plugin, AIS Air Intake, Oil Bypass Filter, Coolant Filter & Dahl Pre-Pump Fuel Filter.
  #10 (permalink)
Old 11-01-2009, 07:22 PM
F350-6's Avatar
Slow Typing
If you've been reading your PC/ED manual, then you should know the first thing you need to do at this point is check for power going to the IDM. Swap the IDM relay, and go ahead and check for voltage as called for in the diagnostic tree.
I don't think your issue is fuel pump or UVCH issues. You can have a UVCH plug come completely off and the truck will still start and run.
__________________
Chris
  #11 (permalink)
Old 11-02-2009, 06:51 PM
Update
Spoke with the shop today - I'm reading in between the lines a little.
First, they said they swapped the IDM with another unit (supposedly a working unit) and still no start.
I asked if they pulled any DTC's and the man said he would check and call back.
No call back, so I called mid-afternoon.
They had pulled four codes: P1663, P1667, P1668 & P1670. I had pulled the same except for the P1670.
They said they found water in my engine's valley - now way. Maybe a small amount of diesel fuel from opening the fuel bowl to disconnect the heater.
They said the IDM connector plug was filled with water and asked if I had pressure washed the engine or driven through some heavy water or possibly left the hood up while raining. No to all the above. Still do not believe water was in the valley.
So they plan to continue their diagnosis with the PCM and they sprayed down the IDM plug with "electrical spray" attempting to dry some of that out for tomorrow's work.
As F350-6 says, they should be checking the power on both sides of the IDM as well as the IDM fuses/relays, etc.
With the DTC's they pulled, one would think they would follow the manual's suggested procedures.
I have read threads talking about how easily water can find its way into the IDM area in the wheel well - there's got to be a better location for such a "animal". Also, one thread revealed a loose IDM ground.
Will continue with this tomorrow.
Thanks,
__________________
  #12 (permalink)
Old 11-02-2009, 08:53 PM
fat j fat j is offline
fat j is starting off with a positive reputation.
hey guys im new to the forum just had a quick ? i have a 01 e-350 power stroke and the problem iv been having is code p306 . the van will not start in the morning if i dont plug it in overnight and when im driving it smokes white on take off and hesitates like it has serous turbo lag iv already relplaced fuel filter /batterys/glowplugs/wire harness under vale covers bothsides for the injectors left side clip on harness was broke that fixed problem with staring and helped cut smoke down to but couple days later it startsd again any thing would help me rite now thanks
  #13 (permalink)
Old 11-02-2009, 09:09 PM
F350-6's Avatar
Slow Typing
Quote:
Welcome to FTE fat j. Please start your own thread so we can work through this and not confuse the issues. My first thought in your case would be the GPR, but the P0306 means you should have a GPCM which would set a different code? Anyway, start a new thread of your own and we'll get this figured out without confusing the original issue in this thread.
__________________
Chris
  #14 (permalink)
Old 11-03-2009, 01:12 PM
USAF CCM's Avatar
USAF CCM USAF CCM is offline
USAF CCM is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by lhud View Post
Update
Thanks,
Subscribing, since I have a 2002 and getting ready to hit the 100,000 mile mark soon. Hope this gets remedied for you soon. V/r Les
__________________
Les
2002 True Blue F350 Ext Cab 4x4 7.3 PSD SRW LB
Rhino Line; 4" BDS Lift; Bilstein Shocks; Centerline Rims; Racor Ext Fuel/Enviro Bypass Oil/Magnafine Trans Filters; 8 Autometer Cobalt Gauges; AIS; Toyo 315/75R16 ATs; Banks Monster Exhaust, Mag-Hytec Trans & Rear Diff Covers; BTS; ATS: AIH Delete; Spearco CAC; DP Tuning; DI SS Ups
30 Yr USAF Vet
  #15 (permalink)
Old 11-03-2009, 05:42 PM
wrtaz's Avatar
wrtaz wrtaz is offline
wrtaz is starting off with a positive reputation.
I'd guess the wire harness under valve covers. Had mine come unpluged a few times and no it will not run. Do a buzz test on the injectors you may find one side not responding. You may also try to have someone push on the plug and see if it'll fire back up. Try both sides.
Tags
60 , access , breakout , connector , died , f350customer , ford , injector , slow , suddenly
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
