Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-31-2009, 02:07 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is gaining momentum as a positive member of FTE.
EOT sensor resistance should be the following ...
0 F = 250K
32 F = 98K
50 F = 59K
160 F = 5.32K
170 F = 4.48K
180 F = 3.75K
190 F = 3.17K
Any radio shack cheap 1/2 watt would work.
__________________
Jim
1997 F250 HD CC 4x4 7.3L - E4OD - 3.55's
EVBP Disconnected - Napa 6637 - FPR Shim
3" Down Pipe & CD - 203 Stat - 163 K Miles
  #17 (permalink)
Old 10-31-2009, 08:11 PM
F350-6's Avatar
F350-6 F350-6 is offline
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Quote:
Originally Posted by muddyforeman View Post
Blowby, A constant push of smoke coming from the dipstick tube. Looks like a fog machine out of the dipstick tube. flipped the oil cap, doesn't blow it off, just kinda vibrates there with the motor.
This is great news. Now ignore the smoke as it has nothing to do with your issues. Let us know what you find on the cold CCT once you get the resistor wired in. You might as well write down the rotational velocity numbers too.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #18 (permalink)
Old 10-31-2009, 10:30 PM
muddyforeman muddyforeman is offline
muddyforeman is starting off with a positive reputation.
Thanks for all the help so far, I'll pick up a resistor at the shak tommorrow after church and check it out as I have to return the Genisys monday .
Ill also take some brake cleaner and clean out the box on the driver's side v/c and see if that has any affect on the issues.
The smoke rolling up out of the dipstick tube does concern me quite a bit though.
  #19 (permalink)
Old 10-31-2009, 10:47 PM
F350-6's Avatar
Slow Typing
Start a poll. You'll be surprised at how many 7.3's have smoke. As long as you don't have any pressure from combustion, you're fine. Mine smokes. It has for at least the last 100,000 miles. I can't really remember when the smoke started. I can tell you the amount of smoke, and the odor of the smoke changes with different types of oils. The ones I've used checked out fine with Blackstone, but I can say Valvoline Premium Blue smokes more than most, and Mobil Delvac stinks pretty bad after about 4,000 miles.
Ignore the smoke and see what the scanner tells you.
__________________
Chris
  #20 (permalink)
Old 11-01-2009, 06:59 AM
DZL JIM's Avatar
DZL JIM DZL JIM is online now
FTE Sponsor
DZL JIM is gaining momentum as a positive member of FTE.
Quote:
0 F = 250K
32 F = 98K
50 F = 59K
160 F = 5.32K
170 F = 4.48K
180 F = 3.75K
190 F = 3.17K
Ok, help me out here.
Does this mean you put in a 4.48k resistor if you want the sensor to put out a signal that it's seeing 170*?
And you'd use a 98k resisitor if you want it to put out a signal for 32*?
Do you know which wire this would go in (there are 2)?
__________________
'96 F-350 Reg Cab 4x4 PSD
'97 F-350 CC Short Bed 4x4 PSD
StackCovers.com
DieselJunk.com
DZLJIM.com
  #21 (permalink)
Old 11-01-2009, 07:50 AM
Hussler's Avatar
You would put the resistor across both wires with the sensor unplugged. You can also unplug the sensor and measure the sensor resistance if you know the oil/water temp to see if it is functioning properly. I have done the latter.
Here is a complete listing for future reference ... Sorry, can't remember where I got it from.
-32F 826K
-30F 785K
-22F 575K
-20F 525K
-10F 365K
-4F 300K
0F 250K
10F 192K
14F 173K
20F 139K
30F 103K
32F 98K
40F 64K
50F 59K
60F 43K
68F 37.3K
70F 33.6K
80F 26.8K
86F 24.3K
90F 21.5K
100F 17.2K
104F 16.1K
110F 13.9K
120F 11.2K
122F 10.9K
130F 9.34K
140F 7.55K
150F 6.28K
158F 5.34K
160F 5.32K
170F 4.48K
176F 3.84K
180F 3.75K
190F 3.17K
194F 2.8K
200F 2.68K
210F 2.2K
212F 2.08K
220F 1.87K
230F 1.56K
240F 1.33K
248F 1.19K
CEL 0.38K
__________________
Jim
  #22 (permalink)
Old 11-01-2009, 09:02 AM
Talyn's Avatar
Talyn Talyn is offline
1994 Ford F-250
Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE.
oh, your taking the sensor out completly and fooling it cause the sensor works on resistance.
Yea, just unplug the sensor then and shove the Resistor in the end of the plug.
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 - F250 - Direct Injection Turbo Diesel, 5 speed, 4x4, Standard Cab.
Rosewood Stage 1's, 6 pos PHP Tuner, 6637, Midwest Short Throw Shift Kit.
Head over to www.midnightmods.com to see some of my projects.
Midwest Shift Kit- http://www.midnightmods.com/2009/11/...ifter-kit.html
  #23 (permalink)
Old 11-01-2009, 09:25 AM
Hussler's Avatar
Correct, the sensor is just a thermistor (variable resistor) sensitive to temperature. Don't know how well the truck will start cold if the PCM thinks oil is hot though.
__________________
Jim
  #24 (permalink)
Old 11-01-2009, 09:32 AM
Talyn's Avatar
1994 Ford F-250
Depending on how long it takes to smooth out.
lets say, it has to idle for 10 mins to smooth out.
start it and let the oil warm slightly, then shut off and plug in the resistor and start again.
I don't think the sensor is really doing anything but letting the truck know whats going on.
Everything on motor's is usually controlled by coolant temps.
__________________
  #25 (permalink)
Old 11-01-2009, 12:47 PM
DZL JIM's Avatar
FTE Sponsor
Truck should start fine with the resistor in a cold motor, just not have the correct timing or fuel available, but should be OK for a CCT.
And it's the Engine Oil Temp that sets the fuel tables, not coolant. In fact, there's no coolant input anywhere to the PCM.
__________________
StackCovers.com
DieselJunk.com
DZLJIM.com
  #26 (permalink)
Old 11-01-2009, 01:35 PM
Well hereis how stands now. Not plugged In. 60 degree ambient temp. Glow plugs are working fine, truck will not start. Cranks and barely hits every 3rd od 4th rotation. Whitish grey smoke from the tailpipe. But refuses to start. All the glow plugs ohm out at the vc harness the glow plug relay is working fine.
Usually I can ug the truck in for a few hrs it will start then be rough till it get all the way warm
  #27 (permalink)
Old 11-01-2009, 04:32 PM
Sorry for the typos in the first post, (iphone). I finally got it started after cranking the weeeeee out of it, It finally hit and fired up to a rough chug. I put the resistor in the EOT plug, tool showed it to be 185. Ran the CCT truck died. Restarted and tried again, Truck died, and a code for the EOT Sensor flagged.
I plugged the EOT back in, Started the truck warmed it up to get the EOT past 160, truck started running a little better. Ran the CCT truck died for a split second, scan tool again popped up and EOT code.
Im beyond stumped at this point, please help
  #28 (permalink)
Old 11-01-2009, 05:01 PM
etldak etldak is offline
1996 Ford F-250
My Garage
etldak is starting off with a positive reputation.
Whats the cod # I'll look it up the chart on alldata
__________________
1988 F250 XLT ex-cab LB 4x4 7.3 5 speed zf. 33/12.50.16.5.true dual 2.50 exhaust. mine
1996 F250 XLT cx-cab LB 2x4 7,3 auto Derale 13700 trans cooler trans,boost pryo gauges,TCI RV Trans.3'' Down Pipe.Hers
  #29 (permalink)
Old 11-01-2009, 07:37 PM
The more I read, am I looking at a fuel pressure problem?
Tags
73 , contribution , diesel , f250 , ford , injection , injector , injectors , pigtails , poppet , powerstroke , test , tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
