Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 08:13 PM
97-psd's Avatar
97-psd 97-psd is offline
97-psd is starting off with a positive reputation.
weak HPOP, now what
well after talking to Jody, finding a gauge, and doing some testing I have found out why my truck smokes so much when running the tunes, my hpop is weak and in need of replacement. It will be fine for awhile as long as I run it in stock, so my question is what should I do now?? Is there some where I can send mine to and let them rebuild it for me, or should I buy a new one? I know I will to upgrade to at least a 17* pump, but where should I get it. I have looked at the adrenaline pump, but right now I am still keeping all of my options on the table, thank you for any suggestions....
__________________
1997 F-350 PSD CC SRW 3.55 5-spd 4x4 273,000 mi and counting
3.5" dp, 3.5" exh. with side-pipe, 140v IDM, DIY intake, Stancor gpr, electric fuel, DP Tuner, and high hopes
www.riffraffdiesel.com
1978 J-10 Sunday driver
  #2 (permalink)
Old 10-29-2009, 09:00 PM
FARM69's Avatar
FARM69 FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
I would check out the Adrenaline pump from Dieselsite. The reviews on good on this system and it's better than running a 17 degree pump.
If I remember correctly the price is hard to beat. I'm pretty sure you can send your pump in and they will re-man it or you can get a new one.
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / HX50 Turbo (19cm) / DP-TUNER / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water/Oil Temp]
4" Straight / 6637 / CCV / 203 Stat
  #3 (permalink)
Old 10-29-2009, 09:03 PM
drivembig's Avatar
drivembig drivembig is offline
drivembig is starting off with a positive reputation.
Where is the guage port to check the pump? I was curious at what mine is putting out.
__________________
2003 Ford F-250 5.4L Triton V-8
1995 Ford F-350 Dually 7.3L Powerstroke Turbo Diesel
1995 Chevrolet 1500 Silverado 5.7L V-8
  #4 (permalink)
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
Check E-Bay They have one every now and then.
Rog
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
  #5 (permalink)
Old 10-29-2009, 09:42 PM
97-psd's Avatar
I used the same port you would use for a HPX, I went to my local hydraulic shop and got a 3000 psi gauge and an adaptor to fit it to the head, my pump would only generate 1500 psi in the race mode at 3200 rpm. it would peak at 2500 psi for just a second while going up through the rpms. I have looked at the adrenaline, and 600 may be a good price, but I thought I heard of of some one who would build up a 15* for a good price but I cannot remember who it was
__________________
  #6 (permalink)
Old 10-30-2009, 12:43 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is starting off with a positive reputation.
I love my adrenaline. I could never get mine over 3k without it missing and bucking. Now I can take it all the way to the red line-smooth.
__________________
Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
  #7 (permalink)
Old 10-30-2009, 01:23 AM
farmer ford's Avatar
farmer ford farmer ford is offline
farmer ford is starting off with a positive reputation.
i think joey at terminator diesel in cali does the 17* rebuilds. i've not been around for a while and never heard of an adreneline pump what is it
__________________
1978.5 F250 stndrd
l. b. 4 speed manual
3" lift 315/75/R16 SXT's
lund moonvisor, custom
paint(dodge blue, viper
silver) home made winch
bumper Warn 9000
diamond plate tool box
1995 F350 4 dr l. b.
PS 5 speed manual
superchips 315/75/R16
SXT's 3" lift, tool box
100gal. transfer tank
6637 intake
  #8 (permalink)
Old 10-30-2009, 01:39 AM
They call it small oil, its inbetween big oil pumps and the 17* they put on SD's. The 17* is alot better then the 15*.
__________________
Glenn
  #9 (permalink)
Old 10-30-2009, 10:08 AM
does adrenilene pump cost alot more than a 17* hpop
__________________
1978.5 F250 stndrd
bumper Warn 9000
PS 5 speed manual
6637 intake
  #10 (permalink)
Old 10-30-2009, 10:19 AM
I you can find a used 17* its cheaper then a adrenaline. The adrenaline is at dieselsite.com.
__________________
Glenn
  #11 (permalink)
Old 10-30-2009, 12:15 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
My Garage
Brown Falcon is starting off with a positive reputation.
The adrenaline is about $600.... not a bad price.
How much do the terminator 17* conversions cost?
__________________
Brownie, Ooh-Rah! USMC Member of the NRA!
'95 F350 CC 4x2 - SRW Swap, E40D, PHP 6 Pos. Chip, 6637 mod, 3" D.P., Lost Kitty, 140v IDM, HPX Mod, FPR Shim (65 psi), T.C. switch, 3.55 gears
'88 F350 CC 4x4 - lots of dents, faded paint, old 7.3 IDI in pieces
  #12 (permalink)
Old 11-01-2009, 12:22 PM
i'll have to call to be sure but i think its about 450. 400 for the kit and 50 to install it into the the housing.
__________________
1978.5 F250 stndrd
bumper Warn 9000
PS 5 speed manual
6637 intake
  #13 (permalink)
Old 11-01-2009, 12:33 PM
crash1's Avatar
crash1 crash1 is offline
crash1 is starting off with a positive reputation.
here comes a dumb Q .WHERE IS THE hpop at
__________________
Curt
go big
12 feet wide 11 feet tall
97 f350 crewcab 1ton dually flat bed ,120 IDM ,3" dp ,5" strait pipe powerstroke 4x4 5 speed conversion
email info@monstertruckrentals.com
  #14 (permalink)
Old 11-01-2009, 01:54 PM
Its up in the front of the motor, in front of the fuel filter housing. The top of the hpop is the tank that holds the oil. The hpop is below that and has two high pressure hoses that come off of it and connects to the heads, one on each side.
__________________
Glenn
  #15 (permalink)
Old 11-01-2009, 02:58 PM
crash1's Avatar
Quote:
THANK YOU ,I just wanted to make sure i was on the same page lol.
__________________
Curt
go big
Tags
1997 , 2000 , 2006 , 350 , 60 , bad , diesel , f250 , ford , hpop , powerstroke , symptoms , turbo , upgrade , v8 , weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
