Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 07:52 PM
pooterbill pooterbill is offline
2003 F250 w/SnoDogg Plow
pooterbill is starting off with a positive reputation.
Lightbulb 2003 F250 w/no power options
Hey guys, My 2003 F250 SD Super Cab XL w 5.4l V8, does NOT have power mirrors, heated mirrors, power windows, power locks.
I have purchased a power/heated tow mirrors . I have purchased power lock kit for the truck. I have purchased a power window kit for the truck. One of the kits has keyless entry and auto start ect ect.
I am disabled and my son-in-law and one of his friends is willing to help install these kits. Is there someplace that I can get all the info on the installation and what all I will need to do this.
I know I may have to make my own harnesses. I have ordered spools of wire and crimp connector kits. Any and all advice is WELCOMED! I use the truck for snow removal and basically all these options will definatley help me stay in the truck instead of having to get in and out during the nice northern Illinois winters.
Also, can I cut out places in my armrest for the switches or should I order new armrest covers that are made for the switches or just get what I need from a good junk yard. Thanks in advance!
  #2 (permalink)
Old 10-29-2009, 09:32 PM
sdetweil's Avatar
sdetweil sdetweil is offline
1955 Ford F-100
sdetweil is gaining momentum as a positive member of FTE. sdetweil is gaining momentum as a positive member of FTE.
usually the power window kits come with switches and wiring harness..
you really only need +12 and ground.. the switches should mount to the face of the door panel or dash.
on the door locks, you should be able to control these with the alarm kit. and a separate window switch would allow you to lock/unlock from inside the truck.
the instructions should be with the kit.. usually for power locks you need two relays to handle the power load.. I just installed these kits in my hotrod.
if the doors were all manual, its unlikely that any wiring was run.. so you will need 4 wires into the door.. 2 for window 2 for lock.
electric start will be the most fun.
then the mirrors are next most fun.. which tow mirrors did you get?
Sam
__________________
55 F100 460/c6, 3.55ls
08 F350 4x2, DRW, CC, LB
  #3 (permalink)
Old 10-29-2009, 10:10 PM
bayou barataria bayou barataria is offline
bayou barataria is gaining momentum as a positive member of FTE.
Wow, sounds like quite a project, I strongly suggest you get someone that has done something like this to help you, the xl truck probably does not come with any factory wiring for the mirrors or doors. Sounds like you will need a power supply fuse block as well. I put one of those alarm kits with the power locks and auto/remote start in one of my hot rods and it must have had about 60 wires. I work with electrical sytems every day and it was quite a chore for me, the power lock relays had me confused for a while. Are these factory mirror and window kits?
__________________
2008 ford f-250 cc 5.4 super duty , raider hi rise camper top with thule ladder racks, front winch bumper top gun, rear bumper top gun,12,000 lb. winch, 98 gal. aux tank, on board 12 volt puma air compressor w/10gal tank and 50' auto hose reel,1000 amp 2nd battery,1,000,2,500,6,000 watt power inverters, 9" hid lights, running boards, air horns by hadley, xm radio, fac. 6 cd nav. center, air bags, cb,2-4'12volt flourescent lights in back.
  #4 (permalink)
Old 10-29-2009, 10:13 PM
msgtg's Avatar
msgtg msgtg is offline
1992 Ford F-150
My Garage
msgtg is a name known to all msgtg is a name known to all msgtg is a name known to all msgtg is a name known to all msgtg is a name known to all msgtg is a name known to all
Bill, if you're patient and willing to search a bit, you'll probably find everything you need here on the site. You may need to stretch out to some of the other forums...like interiors etc, but you should pretty much find it all on here.
As for switches, Ford has a set of blank switch units that are perfect for your truck. They're called "Upfitter" switches.
Joe
__________________
MSgtG 03 F250 King Ranch Crew 6.0 4x4 92 F150 XLT SuperCab 4x2
WV Chapter Lead
JOIN THE WEST VIRGINIA CHAPTER CLICK HERE
2010 MIDATLANTIC MEET, CARLISLE, PA ALL TRUCK NATIONALS More Info Coming Soon
We live in the Land Of The Free...BECAUSE of the Brave! My humble thanks to all Veterans, past and present
  #5 (permalink)
Old 10-29-2009, 10:29 PM
NM04FORD's Avatar
NM04FORD NM04FORD is offline
NM04FORD is starting off with a positive reputation.
I have a 2004 cc 350, manual everything also. I had an alarm installed this summer and had the installer put door lock actuators on the front doors only, got home pulled the door panel to see how they were done. The door locks are simple to do, so I did the rear doors myself in a couple hours. There are no wires ran from the factory, so you will need to do that. I don't think what your about to do will not be very hard just time consuming. I do know being able to unlock the doors for everyone on a CC is much easier now. The right rear door is almost in another county when your in the drivers seat. Good luck.
  #6 (permalink)
Old 11-15-2009, 07:40 PM
Ok, got everthing delivered now. I attached the mirrors to the truck. Now, here is my first problem. I had the old paddle type and the truck has no harness for power heated mirrors. I have the Kool Vue power heated Tow Mirrors FD79ER and FD79EL. The wires coming from the new mirrors are 2 black,1 yellow,1 purple, 1 green, for a total of five. The 2 black, could be 1 blk and 1 brn, my eyes are getting old. I need to know which wire does what.....yep Kool Vue sent NO wiring schematic and no instructions? I have made 2 harnesses with 5 wires each, 1 long for the passenger side and 1 short for the drivers side. Any help on the wiring color would be helpful. Thanks
Tags
2003 , f250 , gas , power , run
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
