Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-29-2009, 07:26 PM
RandyB1986 RandyB1986 is offline
RandyB1986 is starting off with a positive reputation.
Humming Sound when at idle?
I have a 2004 F250 with the 5.4 with 120,000 miles. I noticed the last few months when I am sitting at a stop light or drive thru...the truck makes a humming sound. It is like a noise you get when a power steering use to whine or when the power steering had a vacumn problem.
I do know my air conditioning went out this summer. I got to looking and I think there is a hole in the AC condenser, or whatever it is that looks like and is mounted by the radiator.
Any advice, suggestions or thoughts? I could replace the AC part but I really dont need or use the AC but I am tired of this hmmmmmmmmming.
Thanks,
Randy
  #2 (permalink)
Old 10-30-2009, 12:58 AM
PW_SD PW_SD is offline
PW_SD is starting off with a positive reputation.
Howl Noise Also
MY 04 F-250 SD 5.4 with 147K does the same thing occasionally at idle. Sounds like a deep hum or howl. Goes away when I raise the RPM slightly.
I saw a post regarding this earlier. If I find it I will post the link. It's on my list to solve as well.
If you find anything, let me know
  #3 (permalink)
Old 10-30-2009, 01:25 AM
I came across several post with similar symptoms- no resolution
Do you have a stock air-box or K&N? (I have the K&N)
Here are a few links that I came across that appear similar:
http://www.ford-trucks.com/forums/842904-foghorn.html
http://www.ford-trucks.com/forums/78...ing-noise.html
http://www.ford-trucks.com/forums/19...r-shut-up.html
In the last link, a guy provided a reply with three links that don't open for me. Let me know if you have any sucess.
  #4 (permalink)
Old 10-30-2009, 09:05 AM
My truck is all stock, including air box. Does your truck AC work fine? I'll keep you updated. Thanks!
  #5 (permalink)
Old 10-30-2009, 09:30 AM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE. aldridgec has a very good reputation on FTE.
Check your PCV valve at idle on the passenger side valve cover. They will vibrate when they wear and cause a noise.
__________________
Chris
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
  #6 (permalink)
Old 10-30-2009, 10:04 AM
benbishop benbishop is offline
benbishop is starting off with a positive reputation.
Yeah, under the hood mine was sort of a humming or buzzing sound. It was a bad PCV valve. $4 and 1 minute to change.
  #7 (permalink)
Old 11-05-2009, 09:16 AM
bdschwartz bdschwartz is offline
bdschwartz is starting off with a positive reputation.
2000 5.4
I have a howl when I decelerate on ocassion. Pushing slightly on the accelerator the howl stop immediately. I'm thinking it is the idle air valve. 147K miles and maybe its getting clogged?
Tags
2000 , 2004 , decelerating , engine , f250 , ford , gas , howls , hum , humm , humming , idle , low , make , noise , sound , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
